Hey Folks,
Our implementation has me re-creating instances from a bare DB rather than copying an existing DB, because we have been changing many of the early choices in our setup and configuration as we learn more about the system. For instance we were stuck with an incorrect currency code from early on, and even though we could change the way it was displayed, it made more sense to change the actual currency code during a DB refresh before we went live.
Because of this, and because I didn’t want to rely on building BAQs and maintaining them between systems, I endeavored to make a repo of SQL calls, powershell scripts and playlist csv’s to help me, based on some of the work I’ve seen here on Epiusers (specifically this thread Cloning a company with BAQ Export / DMT - #5 by Paul_Millsaps).
I can’t be the only one to struggle through this, so I thought I’d post the SQL call I use to take a template created in DMT and turn it in to an SQL call I can use to create a CSV from. I will eventually post the larger project structure I use to automate the SQL-> CSV process with powershell (and you could take it further to run the DMTs, but I merely save and run them via playlists).
This was definitely a personal choice, I am not recommending everyone do it this way, but with 2024.2 allowing you to create a BAQ from SQL, this may at least save you a few clicks along the way if you are making BAQs for it.
The SQL call is at the bottom of this post, but as an example, if I build a User Codes template from DMT with the fields I want, I would have a CSV that looks like this:
"Company","CodeTypeID","CodeTypeDesc","UDCodes#CodeTypeID","UDCodes#CodeID","UDCodes#IsActive","UDCodes#CodeDesc"
The parent table name I need is UDCodeType (you can find it in the dropdown of the template builder in DMT where it says All).
There are many ways to find the schema name, but if you already have SSMS or Azure Data Studio open, you might as well just check which one it’s under. For UDCodeType it is Ice
Next you need to do is copy and paste the query below, fill in your @tableName, @tableSchema and @selectedColumns with the data we found above, and run it. If we ran it for UserCodes we’d end up with the following result:
Started executing query at Line 1
(7 rows affected)
(1 row affected)
SELECT
UDCodeType.Company,
UDCodeType.CodeTypeID,
UDCodeType.CodeTypeDesc,
UDCodes.CodeTypeID AS [UDCodes#CodeTypeID],
UDCodes.CodeID AS [UDCodes#CodeID],
(CASE WHEN UDCodes.IsActive = 1 THEN 'True' ELSE 'False' END) AS [UDCodes#IsActive],
UDCodes.CodeDesc AS [UDCodes#CodeDesc]
FROM Ice.UDCodeType
LEFT JOIN Ice.UDCodes ON /* Add your join condition here */
Total execution time: 00:00:00.187
In that result you can see the generated query:
SELECT
UDCodeType.Company,
FROM Ice.UDCodeType
The formatting is up to you, and so is the Join conditions (for User Codes you’d use LEFT JOIN Ice.UDCodes ON UDCodes.CodeTypeID = UDCodeType.CodeTypeID). You can also see that it formats Boolean fields for true/false and names the returned columns to be compatible with DMT.
If it can’t find a field named the same as the column header in the DMT, it will comment it out in the sql (see below Buyer example)
So what can you do with this, and why is useful? To me I use this to extract, filter, manipulate and clean data from our current test environment to load our next one.
Did someone spell your name wrong when they put you in as a buyer? Did you want to make sure everyone has ConsolidatedPurchasing turned off? You could take the base Buyer query generated by the code and add a case to handle it:
SELECT
Company,
CASE
WHEN BuyerID = 'DNOUNAN' THEN 'DNOONAN'
ELSE BuyerID
END AS BuyerID,
-- PerConID,
Name,
POLimit,
ApprovalPerson,
--EMailAddress,
'False' AS ConsolidatedPurchasing
FROM Erp.PurAgent
Did you want to make sure that you don’t end up with duplicate Person/Contact records every time you enter people into the DB? You can join to it based on known data (in this case employee ID’s that I’ve stored in a field our instance doesn’t use):
SELECT
eb.Company,
eb.EmpID,
pc.PerConID AS PerConID,
eb.FirstName,
eb.LastName,
eb.Name,
eb.SupervisorID,
eb.Shift,
(CASE WHEN eb.Payroll = 1 THEN 'True' ELSE 'False' END) AS Payroll,
(CASE WHEN eb.ShopSupervisor = 1 THEN 'True' ELSE 'False' END) AS ShopSupervisor,
(CASE WHEN eb.ShipRecv = 1 THEN 'True' ELSE 'False' END) AS ShipRecv,
(CASE WHEN eb.ProductionWorker = 1 THEN 'True' ELSE 'False' END) AS ProductionWorker,
(CASE WHEN eb.CanRequestMaterial = 1 THEN 'True' ELSE 'False' END) AS CanRequestMaterial,
(CASE WHEN eb.CanReportQty = 1 THEN 'True' ELSE 'False' END) AS CanReportQty,
(CASE WHEN eb.CanReportScrapQty = 1 THEN 'True' ELSE 'False' END) AS CanReportScrapQty,
(CASE WHEN eb.CanReportNCQty = 1 THEN 'True' ELSE 'False' END) AS CanReportNCQty,
eb.ExpenseCode,
eb.JCDept,
eb.ResourceGrpID,
eb.ResourceID,
(CASE WHEN eb.AllowProduction = 1 THEN 'True' ELSE 'False' END) AS AllowProduction,
eb.LaborRate
FROM ERP.EmpBasic eb
LEFT JOIN KineticUAT.Erp.PerCon pc ON pc.IssuerPrsnIDCode = eb.EmpID -- Take the Employee ID from the old DB, and match it to a PerCon record in the new DB's PerCon table. I use the IssuerPrsnIDCode because we don't use this field and it stays unchanged for us
WHERE eb.EmpStatus = 'A'
In the above example I could also change ResourceGrpID, JCDept, Shift, etc. if I need to make a change that was locked in on the old DB.
I realize this was a bit rambly, I’ll clean it up as time permits this week. If you have questions let me know, or find me at the conference Wednesday or Thursday.
Cheers,
Devon
The Super Useful SQL Call:
-- fill in the three variables below, then run the query through SSMS or Azure Data Studio, or your SQL tool of choice
DECLARE @tableName NVARCHAR(128) = ''; -- Name of the parent table for the DMT i.e. UDCodeType for UserCodes
DECLARE @tableSchema NVARCHAR(128) = 'Erp'; -- Erp, Ice, Or whatever schema your table is in
DECLARE @selectedColumns NVARCHAR(MAX) = ''; -- The list of DMT column names without quotes, including the join columns i.e. for User Codes I would use Company,CodeTypeID,CodeTypeDesc,UDCodes#CodeTypeID,UDCodes#CodeID,UDCodes#IsActive,UDCodes#CodeDesc
-- reserved for the call below, don't touch these
DECLARE @columns NVARCHAR(MAX) = '';
DECLARE @joins NVARCHAR(MAX) = '';
DECLARE @sql NVARCHAR(MAX) = '';
-- Step 1: Filtered list of columns into a temp table
SELECT value AS COLUMN_NAME
INTO #ColumnList
FROM STRING_SPLIT(@selectedColumns, ',');
-- Step 2: Identify columns that are bit (boolean-like), columns from other tables, and other columns
SELECT @columns = STRING_AGG(CAST(
CASE
WHEN CHARINDEX('#', cl.COLUMN_NAME) > 0 THEN
CASE
WHEN jc.COLUMN_NAME IS NULL THEN
' -- ' + cl.COLUMN_NAME + ' -- Column not found in schema'
WHEN jc.DATA_TYPE = 'bit' THEN
' (CASE WHEN ' + jt.TableName + '.' + PARSENAME(REPLACE(cl.COLUMN_NAME, '#', '.'), 1) + ' = 1 THEN ''True'' ELSE ''False'' END) AS [' + cl.COLUMN_NAME + ']'
ELSE
' ' + jt.TableName + '.' + PARSENAME(REPLACE(cl.COLUMN_NAME, '#', '.'), 1) + ' AS [' + cl.COLUMN_NAME + ']'
END
WHEN c.COLUMN_NAME IS NULL THEN
WHEN c.DATA_TYPE = 'bit' THEN
' (CASE WHEN ' + @tableName + '.' + c.COLUMN_NAME + ' = 1 THEN ''True'' ELSE ''False'' END) AS ' + c.COLUMN_NAME
ELSE
' ' + @tableName + '.' + c.COLUMN_NAME
END AS NVARCHAR(MAX)), ',' + CHAR(10)
@joins = STRING_AGG(CAST(
CASE
'LEFT JOIN ' + @tableSchema + '.' + PARSENAME(REPLACE(cl.COLUMN_NAME, '#', '.'), 2) + ' ON /* Add your join condition here */'
ELSE
NULL
END AS NVARCHAR(MAX)), CHAR(10))
FROM #ColumnList cl
LEFT JOIN INFORMATION_SCHEMA.COLUMNS c ON c.COLUMN_NAME = cl.COLUMN_NAME AND c.TABLE_NAME = @tableName AND c.TABLE_SCHEMA = @tableSchema
LEFT JOIN INFORMATION_SCHEMA.COLUMNS jc ON jc.COLUMN_NAME = PARSENAME(REPLACE(cl.COLUMN_NAME, '#', '.'), 1) AND jc.TABLE_NAME = PARSENAME(REPLACE(cl.COLUMN_NAME, '#', '.'), 2) AND jc.TABLE_SCHEMA = @tableSchema
LEFT JOIN (
SELECT DISTINCT PARSENAME(REPLACE(cl.COLUMN_NAME, '#', '.'), 2) AS TableName
FROM #ColumnList cl
WHERE CHARINDEX('#', cl.COLUMN_NAME) > 0
) jt ON jt.TableName = PARSENAME(REPLACE(cl.COLUMN_NAME, '#', '.'), 2);
-- Step 3: Ensure only one join per table
SELECT DISTINCT jt.TableName
INTO #JoinTables
FROM #ColumnList cl
LEFT JOIN (
FROM #ColumnList cl
WHERE CHARINDEX('#', cl.COLUMN_NAME) > 0;
SELECT @joins = STRING_AGG(CAST(
'LEFT JOIN ' + @tableSchema + '.' + jt.TableName + ' ON /* Add your join condition here */' AS NVARCHAR(MAX)), CHAR(10))
FROM #JoinTables jt;
-- Step 4: Construct the SELECT query
SET @sql = 'SELECT ' + CHAR(10) + @columns + CHAR(10) + 'FROM ' + @tableSchema + '.' + @tableName + CHAR(10) + ISNULL(@joins, '');
-- Step 5: Output the generated SQL query
-- SELECT @sql AS GeneratedSQL;
WHILE LEN(@sql) > 0
BEGIN
PRINT LEFT(@sql, 4000); -- PRINT only handles up to 4000 characters at a time
SET @sql = SUBSTRING(@sql, 4001, LEN(@sql)); -- Continue from where left off
END
-- Cleanup
DROP TABLE #ColumnList;
DROP TABLE #JoinTables;
