DMT Transfer of PO
You will need to unapproved all POs and after the import run a DMT to approve the PO.  If you are bringing over closed POs and or closed lines on open POs you will need to re-open and close once the DMT is complete.
The DMT tool is used to make sure you do not circumvent the system.
Sent from my iPad
On Mar 21, 2014, at 6:29 PM, <marcus@...> wrote:
<div id="ygrps-yiv-85045209ygrp-text">
  <p>Hi fellow E9 Users,</p><div><br></div><div>My company is upgrading from Vantage to E9 and we are in the process of importing data into our pilot system for CRP. We have successfully transferred Customer, Supplier, Part &amp; MOM, Quote, Order, Job, and RMA&#39;s, but we are having major difficulties with transferring in all our PO&#39;s. We are using the DMT tool and we keep getting errors ever time we try to process our data. When we upload the PO Header table we get the following errors:</div><div><br></div><div>Table: POHeader Msg: Purchase order 130889 is approved, cannot update.<br></div><div>Table: POHeader Msg: Purchase order 131201 is closed, cannot update.<br></div><div>Table: PODetail Msg: The PO had been approved. &nbsp;Changes not allowed.<br></div><div>Table: &nbsp;Msg: A valid part is required<br></div><div>Table: POHeader Msg: PO is not approved and cannot be flagged as Ready To Print.<br></div><div><br></div><div>We were under the impression that the DMT tool could circumvent the restrictions of updating PO&#39;s regardless of whether they are approved/closed/void. Has anyone else had a problem uploading PO&#39;s?</div><div><br></div><div>The current fields we are trying to import are as follows:</div><div>Company</div><div>OpenOrder</div><div>VoidOrder</div><div>PONum</div><div>EntryPerson</div><div>FOB</div><div>ShipViaCode</div><div>TermsCode</div><div>BuyerID</div><div>VendorNum</div><div>OrderHeld</div><div>ReadyToPrint</div><div>PrintAs</div><div>Approve</div><div>ApprovalStatus</div><div>ApprovedAmount</div><div>OrderNum</div><div>PODetail#Company</div><div>PODetail#OpenLine</div><div>PODetail#VoidLine<br></div><div>PODetail#PONum<br></div><div>PODetail#POLine<br></div><div>PODetail#LineDesc<br></div><div>PODetail#IUM<br></div><div>PODetail#UnitCost<br></div><div>PODetail#DocUnitCost<br></div><div>PODetail#Taxable<br></div><div>PODetail#PUM<br></div><div>PODetail#CostPerCode<br></div><div>PODetail#PartNum<br></div><div>PODetail#VenPartNum<br></div><div>PODetail#RevisionNum<br></div><div>PODetail#RcvInspectionReq<br></div><div>PODetail#VendorNum<br></div><div>PODetail#Confirmed<br></div><div>PODetail#ConfirmedDate<br></div><div>PODetail#OrderNum<br></div><div>PODetail#OrderLine<br></div><div>PODetail#CalcOurQty<br></div><div>PORel#Company<br></div><div>PORel#PONum<br></div><div>PORel#POLine<br></div><div>PORel#PORelNum<br></div><div>PORel#OpenRelease<br></div><div>PORel#VoidRelease<br></div><div>PORel#DueDate<br></div><div>PORel#XRelQty<br></div><div>PORel#PurchasingFactor<br></div><div>PORel#RelQty<br></div><div>PORel#JobNum<br></div><div>PORel#AssemblySeq<br></div><div>PORel#JobSeqType<br></div><div>PORel#JobSeq<br></div><div>PORel#WarehouseCode<br></div><div>PORel#ReceivedQty<br></div><div>PORel#ExpOverride<br></div><div>PORel#Plant<br></div><div>PORel#PromiseDt<br></div><div>PORel#ProjectID<br></div><div>PORel#Comfirmed<br></div><div>PORel#ConfirmVia<br></div><div>PORel#OrderNum<br></div><div>PORel#OrderLine<br></div><div>PORel#OrderRelNum<br></div><div>PORel#ShippedQty<br></div><div><br></div><div>Are there any fields you suggest we include/exclude to/from this list? Any help would be much appreciated!</div><div><br></div><div>Thanks,</div><div>-Marcus</div><div><br></div><div><br></div><div><br></div><div><br></div><p></p>
</div>
Hi fellow E9 Users,
My company is upgrading from Vantage to E9 and we are in the process of importing data into our pilot system for CRP. We have successfully transferred Customer, Supplier, Part & MOM, Quote, Order, Job, and RMA's, but we are having major difficulties with transferring in all our PO's. We are using the DMT tool and we keep getting errors ever time we try to process our data. When we upload the PO Header table we get the following errors:
Table: PODetail Msg: The PO had been approved.  Changes not allowed.
Table:  Msg: A valid part is required
We were under the impression that the DMT tool could circumvent the restrictions of updating PO's regardless of whether they are approved/closed/void. Has anyone else had a problem uploading PO's?
Company
OpenOrder
VoidOrder
PONum
EntryPerson
FOB
ShipViaCode
TermsCode
BuyerID
VendorNum
OrderHeld
ReadyToPrint
PrintAs
Approve
ApprovalStatus
ApprovedAmount
OrderNum
PODetail#Company
PODetail#OpenLine
PODetail#VoidLine
PODetail#PONum
PODetail#POLine
PODetail#LineDesc
PODetail#IUM
PODetail#UnitCost
PODetail#Taxable
PODetail#PUM
PODetail#PartNum
PODetail#VenPartNum
PODetail#VendorNum
PODetail#Confirmed
PODetail#OrderNum
PODetail#OrderLine
PODetail#CalcOurQty
PORel#Company
PORel#PONum
PORel#POLine
PORel#PORelNum
PORel#OpenRelease
PORel#VoidRelease
PORel#DueDate
PORel#XRelQty
PORel#RelQty
PORel#JobNum
PORel#AssemblySeq
PORel#JobSeqType
PORel#JobSeq
PORel#WarehouseCode
PORel#ReceivedQty
PORel#ExpOverride
PORel#Plant
PORel#PromiseDt
PORel#ProjectID
PORel#Comfirmed
PORel#ConfirmVia
PORel#OrderNum
PORel#OrderLine
PORel#OrderRelNum
PORel#ShippedQty
-Marcus
DMT follows all business rules. When I was taught how to troubleshoot a DMT run, the process was to attempt the same update in the client and make note of any requirements that you will need to meet in the upload file.
I first uploaded Headers with Approve set to false and then the same set with Approve true and ApprovalStatus = A when done.
I did not use PO Combined when I did mine, but I would assume you would still do combined as unapproved and then a header file to approve them all.
Good Luck
Greg Payne
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of marcus@...
Sent: Friday, March 21, 2014 6:30 PM
Subject: [Vantage] DMT Transfer of PO
Hi fellow E9 Users,
Company
OpenOrder
VoidOrder
PONum
EntryPerson
FOB
ShipViaCode
TermsCode
BuyerID
VendorNum
OrderHeld
ReadyToPrint
PrintAs
Approve
ApprovalStatus
ApprovedAmount
OrderNum
PODetail#Company
PODetail#OpenLine
PODetail#VoidLine
PODetail#PONum
PODetail#POLine
PODetail#LineDesc
PODetail#IUM
PODetail#UnitCost
PODetail#Taxable
PODetail#PUM
PODetail#PartNum
PODetail#VenPartNum
PODetail#VendorNum
PODetail#Confirmed
PODetail#OrderNum
PODetail#OrderLine
PODetail#CalcOurQty
PORel#Company
PORel#PONum
PORel#POLine
PORel#PORelNum
PORel#OpenRelease
PORel#VoidRelease
PORel#DueDate
PORel#XRelQty
PORel#RelQty
PORel#JobNum
PORel#AssemblySeq
PORel#JobSeqType
PORel#JobSeq
PORel#WarehouseCode
PORel#ReceivedQty
PORel#ExpOverride
PORel#Plant
PORel#PromiseDt
PORel#ProjectID
PORel#Comfirmed
PORel#ConfirmVia
PORel#OrderNum
PORel#OrderLine
PORel#OrderRelNum
PORel#ShippedQty
-Marcus
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
