DMT UD100A - ChildKey1
I need to DMT records into the UD100A table. I need to populate the field “ChildKey1” thru “ChildKey5” does anyone know what to put here to make the record unique? For Key1-Key5 I am referencing the same data as was loaded for UD100.
I am putting in a value in ChildKey1, but getting the error:
“Record for update was not found by its SysRowID value [00000000-0000-0000-0000-000000000000].”
did you forget to populate the Company field? It is normally required.
The company field is populated. I just put a fill block on it so as to not share that on this forum.
I figured out the issue. It was with how the UD100 table was setup. Worked now as shown above!
Hi maverick,
How did you setup your UD table?
Hi ,how did you setup it plz ??!
