DMT Verbosity setting?
With the DMT update from .44 to .45, the information in Errors.txt has changed radically. It now includes way to much extra info to be readable or usable. Does anyone know of a way to turn this off?
Example from .44:
2019-07-15T08:26:03 R51132/16 0 2 Table: JobOper Msg: Supplier ID is invalid. Table: JobOper Msg: Supplier Purchase Point is invalid.
2019-07-15T08:26:03 R51132/16 0 5 Table: JobOper Msg: Supplier ID is invalid. Table: JobOper Msg: Supplier Purchase Point is invalid.
Example from .45 (same source data as above):
at Epicor.ServiceModel.Channels.ImplBase1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets) at Erp.Proxy.BO.JobEntryImpl.Update(JobEntryDataSet ds) at Epicor.DMT.Lib.JobOpr.setValues(ExtendedBackgroundWorker worker, Int32 cur, Boolean containsOpStdID, Boolean containsOpComplete, Boolean isMaintanenceJob, DataRow dr, JobOperRow row, JobEntryDataSet ds, JobEntryImpl job) at Epicor.DMT.Lib.JobOpr.Import(ImportData data, ExtendedBackgroundWorker worker) 2019-07-15T08:26:03 R51132/16 0 5 Table: JobOper Msg: Supplier ID is invalid. Table: JobOper Msg: Supplier Purchase Point is invalid. Supplier ID is invalid. at Epicor.ServiceModel.Channels.ImplBase1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets)
Epicor support is saying that there is on way to turn it off but that they will make this a feature request.
