Document attachments in Epicor
In the Files Section of the group under the C# .Net programs is an example
program that will change the location of attachments.
Mark W.
On Tue, Jul 31, 2012 at 4:55 PM, Kirstin Brandt <kirstin.brandt@...
> wrote:
> We recently had to move a whole bunch of files and the easiest solution I
> found was to go to External File Reference Maintenance, pull up all your
> files. Go to list view and copy all. Paste them in Excel and get creative
> with formulas to change the paths in the "file name", then paste update
> back into list view.
> --- In vantage@yahoogroups.com, Mike Tonoyan <mtonoyan@...> wrote:
> > Just recently we added a new domain controller and upgraded 1 virtual
> DC, one of the old VDC is still running. After the upgrade several laptops
> and PCs are having difficulty to open PDF files. The attachment links point
> to our intranet, \\intranet\documents\test.pdf<file:///\\intranet\documents\test.pdf>.
> If we change the back slashes with forward slashes,
> //intranet/documents/test.pdf then the links work. It is not possible to
> change thousands of document attachment links because of these few
> workstations.
> > I have tried to release and renew the IP addresses, flushdns, none of
> that helped.
> > Any ideas? We will really appreciate your input.
> > Mike Tonoyan / Natel EMS
> > mtonoyan@...
> > __________________________________________________________
> > Notice: This email transmission may contain confidential information and
> is intended only for the person(s) named. Any use, copying or disclosure
> to/by any other person(s) is strictly prohibited. By accepting this
> information, recipients confirm that they understand and will comply with
> all applicable ITAR and EAR requirements.
I am trying to add color to a shape based on a checkbox.
This is my event wizard
private static void epiCheckBoxC2_CheckedChanged(object sender, System.EventArgs args)
If epicheckboxC2.checked = true then;
EpiShape.Enabled=true;
Else;
EpiShape.Enabled=false;
End If;
Output:
Compiling Custom Code ...
----------errors------------
Error: CS1002 - line 401 (2782) - ; expected
Error: CS1525 - line 401 (2782) - Invalid expression term '.'
Error: CS1514 - line 401 (2782) - { expected
Error: CS1525 - line 401 (2782) - Invalid expression term '='
** Compile Failed. **
Can anyone help?
You are writing VB code in C# or a weird combination there of.
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.usdoingstuff.com>
> Else;
> End If;
> Output:
> Can anyone help?
C#
With an added touch.
Rick Hagy
Of Jose Gomez
Sent: Tuesday, July 31, 2012 1:56 PM
Subject: Re: [Vantage] epishape
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Else;
> End If;
> Output:
> Can anyone help?
So are you 9x? or 8x? If 9X are you doing C# or VB? So that we can help
thanks@
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Tue, Jul 31, 2012 at 2:01 PM, Rick Hagy <rhagy@...> wrote:
> C#
> Rick Hagy
> Of Jose Gomez
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Else;
> > End If;
> > Output:
> > Can anyone help?
9x and I am using C#
Rick Hagy
Project Manager
Tel: (804) 523-8115
Fax: (804) 523-8150
http://www.openplan.com
HMU, LLC d/b/a Open Plan Systems
4700 Deepwater Terminal Rd | Richmond, VA 23234
Of Jose Gomez
Sent: Tuesday, July 31, 2012 2:13 PM
thanks@
*Jose C Gomez*
*Software Engineer*
E: jose@...
> C#
> Rick Hagy
Behalf
> Of Jose Gomez
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Else;
> > End If;
> > Output:
> > Can anyone help?
Ok.
C# doesn't have else then or end if
If epichecbkbox2.Checked==true
else
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Rick Hagy
> Project Manager
> Tel: (804) 523-8115
> Fax: (804) 523-8150
> Of Jose Gomez
> thanks@
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > C#
> > Rick Hagy
> Behalf
> > Of Jose Gomez
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > > Else;
> > > End If;
> > > Output:
> > > Can anyone help?
If epicheckboxC2.Checked==true;
EpiShapeC1.Enabled=true;
Else;
EpiShapeC1.Enabled=false;
Output
Error: CS1002 - line 399 (2780) - ; expected
Error: CS1525 - line 399 (2780) - Invalid expression term '.'
What am I missing... so close.
Rick Hagy
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Rick Hagy
> Project Manager
> Tel: (804) 523-8115
> Fax: (804) 523-8150
Behalf
> Of Jose Gomez
help
> thanks@
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > C#
> > Rick Hagy
> Behalf
> > Of Jose Gomez
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > > Else;
> > > End If;
> > > Output:
> > > Can anyone help?
must
access.
Builder
Just recently we added a new domain controller and upgraded 1 virtual DC, one of the old VDC is still running. After the upgrade several laptops and PCs are having difficulty to open PDF files. The attachment links point to our intranet, \\intranet\documents\test.pdf<file:///\\intranet\documents\test.pdf>. If we change the back slashes with forward slashes, //intranet/documents/test.pdf then the links work. It is not possible to change thousands of document attachment links because of these few workstations.
I have tried to release and renew the IP addresses, flushdns, none of that helped.
mtonoyan@...
______________________________________________________________________
Notice: This email transmission may contain confidential information and is intended only for the person(s) named. Any use, copying or disclosure to/by any other person(s) is strictly prohibited. By accepting this information, recipients confirm that they understand and will comply with all applicable ITAR and EAR requirements.
Your Else doesn't need a semi colon.
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Else;
> Output
> Rick Hagy
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Rick Hagy
> > Project Manager
> > Tel: (804) 523-8115
> > Fax: (804) 523-8150
> Behalf
> > Of Jose Gomez
> help
> > thanks@
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > > C#
> > > Rick Hagy
> > Behalf
> > > Of Jose Gomez
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@...
> > > > Else;
> > > > End If;
> > > > Output:
> > > > Can anyone help?
> must
> access.
> Builder
Sorry...
My error is on line 400 which is the if statement.
Error: CS1002 - line 400 (2781) -; expected
Line 400:
If epiCheckBoxC2.Checked==true;
Rick Hagy
Project Manager
Tel: (804) 523-8115
Fax: (804) 523-8150
Of Jose Gomez
Sent: Tuesday, July 31, 2012 2:55 PM
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Else;
> Output
> Rick Hagy
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Rick Hagy
> > Project Manager
> > Tel: (804) 523-8115
> > Fax: (804) 523-8150
> Behalf
> > Of Jose Gomez
> help
> > thanks@
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
wrote:
> > > C#
> > > Rick Hagy
> > Behalf
> > > Of Jose Gomez
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@...
> > > > Else;
> > > > End If;
> > > > Output:
> > > > Can anyone help?
> must
> access.
> Builder
must
access.
Builder
Jose,
I figured it out, thanks for your help.
Rick Hagy
Project Manager
Tel: (804) 523-8115
Fax: (804) 523-8150
http://www.openplan.com <http://www.openplan.com/>
Of Rick Hagy
Sent: Tuesday, July 31, 2012 3:00 PM
Subject: RE: [Vantage] epishape
Sorry...
Line 400:
Rick Hagy
Project Manager
Tel: (804) 523-8115
Fax: (804) 523-8150
Behalf
Of Jose Gomez
*Jose C Gomez*
*Software Engineer*
E: jose@... <mailto:jose%40josecgomez.com>
> Else;
> Output
> Rick Hagy
> *Jose C Gomez*
> *Software Engineer*
> > Rick Hagy
> > Project Manager
> > Tel: (804) 523-8115
> > Fax: (804) 523-8150
> Behalf
> > Of Jose Gomez
> help
> > thanks@
> > *Jose C Gomez*
> > *Software Engineer*
wrote:
> > > C#
> > > Rick Hagy
> > Behalf
> > > Of Jose Gomez
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > > Else;
> > > > End If;
> > > > Output:
> > > > Can anyone help?
> must
> access.
> Builder
must
access.
Builder
We recently had to move a whole bunch of files and the easiest solution I found was to go to External File Reference Maintenance, pull up all your files. Go to list view and copy all. Paste them in Excel and get creative with formulas to change the paths in the "file name", then paste update back into list view.
> mtonoyan@...
