Document management
Sandy -
Save yourself the typing ! You don't need the http:// just enter the
website
www.urlthatyouwant.com
You also need to specify where the iexplore.exe is found on the pc when you
created the document association from the System Management menu. To make
things
simple, I put a copy of the program at the root of the C drive on each pc.
This
way I don't worry if XP is different from 2000 or 98. Each OS puts the file
in
a different directory - by putting a copy on the root of the C drive I
remove
that problem!
Here is my view command (character for character):
c:\iexplore.exe &1
If you use the iexplore.exe for xls, doc, txt, log, pdf, and com
(websites) - you
only have to reference 1 program for all document types. You still need to
set
up the association for each but that's easier than 6 different executables.
HTH,
Calvin
Sent: Sunday, March 06, 2005 9:38 AM
Subject: [Vantage] Document management
Shirley & Calvin,
I am missing something because I tried to get the .com to work and
nothing happens when I click view. I am setting up com in "Document
Association" with the path to iexplore.exe followed by &1. Then in a
test part number revision I am putting in
http://www.urlthatIwanttouse.com It associates to the com record but
Thanks!
Sandy Morse
BVR Technologies Company
815-874-2471 x112
Yahoo! Groups Links
Does anybody know of a way to have files attached through document
management to automatically print with the traveler? We have laser / turret
punch setup sheets that we print each time we run a job. I am hoping there
is an alternative to Vantage custom programming.
TIA
Dan Shallbetter
States Electric Mfg.
What are some common uses for Document Management that some of you have found useful? We have had the module for two years. Haven't touched it. Wondering if I should.
Anyone care to give some input here?
Troy Funte
Liberty Electronics
Troy,
Document Management was key to our QS9000 certification. We have virtually
eliminated ALL paper files for our process cards. The only versions of our
process cards that exist are electronic. The supervisor prints out the
process cards as needed, at the end of a job these cards are discarded.
Only our Process Engineer, and the Document Manager (myself) can make
changes in those directories, (NT security). Our QS auditor said that it
was rare to have a document system that made it virtually impossible NOT to
have the most current version of process card.
Shirley
Sent: Wednesday, July 18, 2001 8:58 PM
To: Vantage
Troy Funte
Liberty Electronics
Crystal Reports and other 'goodies', please go to:
http://groups.yahoo.com/group/vantage/files/. Note: You must have already
Shirley,
Reading the HELP on Document Management, it says there is an icon available to click. So far, I have only found such an icon when editing Part Rev's. What other places in Vantage can access DM files? Where do the links show up that a user would click for your process cards?
Troy Funte
Liberty Electronics
----- Original Message -----
Sent: Thursday, July 19, 2001 6:23 AM
Subject: RE: [Vantage] Document management
Troy,
Shirley
To: Vantage
Troy Funte
Liberty Electronics
To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please go to: http://groups.yahoo.com/group/vantage/files/. Note: You must have already linked your email address to a yahoo id to enable access.
Troy,
There are 3 places you can associate documents. Quotes (line items), Jobs
(line items), and Part Rev. What we've done is to create a templet sheet in
excel. Then we hyperlink all the pertinent process cards to this one sheet.
Then we use document management to link to the part. The supervisor can
then use part tracker for the part/job he is setting up and click on what
ever process card he needs. When first put in I staged a test, I had
someone give me and the supervisor the same part number at the same time to
see who could get all the process cards 1st. I was able to pull up and
print 5 associated process cards in less than 5 minutes. The supervisor was
still going through the paper file for his first card after 10 minutes.
There was no more resistance after that.
Personally I would like to see document links in EVERY Vantage
module. Its too useful a tool to be restricted to 3 areas.
Shirley
Sent: Thursday, July 19, 2001 9:58 AM
Subject: Re: [Vantage] Document management
Shirley,
Troy Funte
Liberty Electronics
Troy,
virtually
our
to
Shirley
To: Vantage
Troy Funte
Liberty Electronics
already
< http://docs.yahoo.com/info/terms/> .
Shirley, we did not buy the DM module because of the limited areas of
access. It is relatively easy to link to external documents from a VB form.
We have found this very useful to link items such as customer POs to sales
orders and spreadsheets to Vendor master files. Anywhere there is a VB form
you set up a link.
Just a thought ...
Jerry Boyle
Sipco Molding Technologies
Meadville, Pa. 16335-6725
814.724.2243
Visit our web site at www.sipco.com
Sent: Thursday, July 19, 2001 11:07 AM
Troy,
Shirley
Jerry,
And an Excelent thought it is too, I haven't looked at it in detail, and I
may add that feature in the future. I have a problem with many users who
simply HATE the VB forms button.
Shirley
Sent: Thursday, July 19, 2001 12:27 PM
you set up a link.
Just a thought ...
Jerry Boyle
814.724.2243
Troy,
Shirley
Yahoo! Groups Sponsor
ADVERTISEMENT
Lose 20 lbs by September 24th!
<http://rd.yahoo.com/M=210574.1511967.3081913.1261774/D=egroupweb/S=17050071
83:HM/A=725669/R=0/*http://ads.track-star.com/adspace.ts?ts=1;2;217;107_133_
105_303>
Been there, change the name of the VB Form button for each screen using a
translation and most (never say all) of the resistance fades.
Jerry Boyle
814.724.2243
Sent: Thursday, July 19, 2001 1:23 PM
Jerry,
Shirley
Now you guys are talking another language again, and bringing up a new topic which my curious mind will want to figure out -- VB forms. Once again, I've heard of VB forms, never touched it, but plan to try to figure it out.
Jerry, do you use VB forms INSTEAD of Document Management?
Troy Funte
Liberty Electronics
Sent: Thursday, July 19, 2001 4:42 PM
Jerry Boyle
814.724.2243
Jerry,
Shirley
Jerry, can you explain how you change the name of that 'VB Forms' button. I
hate that we cannot change that name and would love to be able to do it.
using a
Jerry Boyle
I'm not that familiar with the DM module so I hesitate to say that using VB
Forms to link documents is a replacement for it. I'm sure there must be
other features. We use VB Forms simply to link documents such as Customer
POs to Sales Orders and spreadsheets to Vendor/Customer master files. Not
real sophisticated, but it is really nice when you are reviewing a Sales
Order in tracker to be able to view a copy of the actual customer PO.
Jerry Boyle, IS Manager
814.724.2243
Sent: Friday, July 20, 2001 4:05 PM
Troy Funte
Liberty Electronics
If you are not familiar with language maintenance you probably should talk
to someone at Epicor to get detailed instructions. If not done right you
could get some unexpected results. That said, it is not real involved. You
create your own language (by copying your default one) and then you can do
on-line translations specific to a program or screen. Try it in your
training database to get the results you want first. The on-line help was
very useful. It explains how you need to edit your .vtg files and how to do
exports and imports of languages. I have only done a couple of simple
changes but they have been helpful. Change "VB Form" to "Kool Stuff" and,
for some reason, users are more willing to use it.
814.724.2243
From: sarah.vareschi@... [mailto:sarah.vareschi@...]
Sent: Friday, July 20, 2001 4:14 PM
Shirley & Calvin,
Thanks!
Sandy Morse
815-874-2471 x112
