Pat - leave the space in folder ( or document ) name ... Just use quotes
around the name IN the path statement.
IE X:\folder\xxx\"names with spaces"\"documents about vantage.doc"
Todd Anderson
Sent: Wednesday, September 27, 2000 11:52 AM
To: 'vantage@egroups.com'
Subject: RE: [Vantage] Document Manager - Document Path
I found my problem, one of my file folders had a space in the name "Punch
Casings".
Thanks for the help.
Patrick J. Winter
Information Services Manager
sSc Specialty Screw Corporation
Vantage 3.00.614, Progress 8.3A
Sent: Wednesday, September 27, 2000 11:43 AM
256 characters in V 4.0 .... V 3.0 it was something like 60 or 80 characters
for the entire path name so in V3.0 you had to watch how deep your directory
structure went.
We have something like 600 customers and 10-15,000 items so we setup our
folders as:
\cst\a-f\custname\part-number\..... docs
\cst\g-l\custname\part-number\..... docs
\cst\m-q\custname\part-number\.... docs
\cst\r-z\custname\part-number\.... docs
You could also add \rev\ after part-number ( a,b,c etc ).
The idea was to make it easy to find all documents related to one item
easily with or without doc-mgmt.
Not that this idea makes much sense ... I just wasn't coming up with a
better idea at the time.
The one downside to this arrangement ... a folder for one item can contain
drawings, quotes ( word ), and/or inspection documents. That's 3 different
departments that need read-write access to the folder and hence to each
other's "Stuff" while the shop floor is read-only to everything. I'd love
to be able to set the access privileges by file extension but can't do it
under NT and setting up separate directory trees for each department seemed
very redundant just to protect "Turf".
Yada Yada Yada
Todd Anderson
eGroups Sponsor
<http://click.egroups.com/1/9500/13/_/411782/_/970077280/>
<http://adimg.egroups.com/img/9500/13/_/411782/_/970077280/468x60_hate_searc
hing5.gif>
<http://www.egroups.com/files/vantage/>
Todd Anderson
Casings".
Patrick J. Winter
structure went.
folders as:
Yada Yada Yada
Todd Anderson
eGroups Sponsor
hing5.gif>
