Yeah, for our setup the user that's logged into the domain is passed across to Sharepoint as the authenticated user to upload the document to the site.
You could try editing the permissions on the sharepoint and modify the Visitors group to allow Contribute permissions and see if that does the trick. By default Visitors are read only.
--- In vantage@yahoogroups.com, Jose Gomez <jose@...> wrote:
> Just tested it from the site and it works fine although I hve to be logged
> in...
> Any way to make Vantage authenticate ? As far as I can tell there is no way
> to allow uploads from non authenticated users.
> Sincerely
> Jose C Gomez
> http://www.josecgomez.com
> On Tue, Nov 3, 2009 at 10:11 AM, pbparker <scrumbus@...> wrote:
> > Try adding an attachment directly to the Sharepoint site from your web
> > browser to the folder that Vantage created to see if Sharepoint is working
> > without going through Vantage. If the error still happens then you know it's
> > something within Sharepoint itself.
> > --- In vantage@yahoogroups.com <vantage%40yahoogroups.com>, Jose Gomez
> > <jose@> wrote:
> > > No there aren't any weird entries in the event log of the SharePoint
> > site.
> > > I've made the share point site allow anonymous access cause I can't find
> > > anywhere how to authenticate the Vantage User but other than that
> > everything
> > > is normal.
> > > Sincerely
> > > Jose C Gomez
> > > Sent from Jacksonville, Florida, United States
> > > On Fri, Oct 30, 2009 at 3:57 PM, pbparker <scrumbus@> wrote:
> > > > There any event log errors or entries on the server that's hosting
> > > > SharePoint?
> > > > --- In vantage@yahoogroups.com <vantage%40yahoogroups.com> <vantage%
> > > > <jose@> wrote:
> > > > > Hello All,
> > > > > We are trying to use Share Point with Epicor 9 for our document
> > > > management
> > > > > we have successflly create the library on our site and then we go to
> > > > create
> > > > > an attachment the system creates the appropriate folder but after
> > that we
> > > > > get this error on the Vantage Side adnt he file is not attached
> > > > > The following application error was encountered:
> > > > > Copy operation 1 failed.
> > > > > Error: Object reference not set to an instance of an object.
> > > > > Code: Unknown
> > > > > Any ideas?
> > > > > Thanks!
> > > > > Sincerely
> > > > > Jose C Gomez
> > > > > [Non-text portions of this message have been removed]
