#ygrps-yiv-1654679048
_filtered #ygrps-yiv-1654679048 {font-family:Wingdings;
panose-1:5 0 0 0 0 0 0 0 0 0;}
_filtered #ygrps-yiv-1654679048 {font-family:Calibri;
panose-1:2 15 5 2 2 2 4 3 2 4;}
_filtered #ygrps-yiv-1654679048 {font-family:Tahoma;
panose-1:2 11 6 4 3 5 4 4 2 4;}
_filtered #ygrps-yiv-1654679048 {font-family:Consolas;
panose-1:2 11 6 9 2 2 4 3 2 4;}
_filtered #ygrps-yiv-1654679048 {font-family:Verdana;
#ygrps-yiv-1654679048 p.ygrps-yiv-1654679048MsoNormal, #ygrps-yiv-1654679048 li.ygrps-yiv-1654679048MsoNormal, #ygrps-yiv-1654679048 div.ygrps-yiv-1654679048MsoNormal
{margin:0in;
margin-bottom:.0001pt;
font-size:12.0pt;
font-family:"Times New Roman", "serif";}
#ygrps-yiv-1654679048 a:link, #ygrps-yiv-1654679048 span.ygrps-yiv-1654679048MsoHyperlink
color:blue;
text-decoration:underline;}
#ygrps-yiv-1654679048 a:visited, #ygrps-yiv-1654679048 span.ygrps-yiv-1654679048MsoHyperlinkFollowed
color:purple;
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
font-family:“Times New Roman”, “serif”;}
#ygrps-yiv-1654679048 code
font-family:“Courier New”;}
#ygrps-yiv-1654679048 pre
margin:0in;
font-size:10.0pt;
#ygrps-yiv-1654679048 tt
#ygrps-yiv-1654679048 span.ygrps-yiv-1654679048HTMLPreformattedChar
font-family:“Consolas”, “serif”;}
#ygrps-yiv-1654679048 p.ygrps-yiv-1654679048attach, #ygrps-yiv-1654679048 li.ygrps-yiv-1654679048attach, #ygrps-yiv-1654679048 div.ygrps-yiv-1654679048attach
margin-right:0in;
margin-left:0in;
font-size:9.0pt;
font-family:“Arial”, “sans-serif”;}
#ygrps-yiv-1654679048 p.ygrps-yiv-1654679048bold, #ygrps-yiv-1654679048 li.ygrps-yiv-1654679048bold, #ygrps-yiv-1654679048 div.ygrps-yiv-1654679048bold
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
font-weight:bold;}
#ygrps-yiv-1654679048 p.ygrps-yiv-1654679048green, #ygrps-yiv-1654679048 li.ygrps-yiv-1654679048green, #ygrps-yiv-1654679048 div.ygrps-yiv-1654679048green
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
color:#628C2A;}
#ygrps-yiv-1654679048 p.ygrps-yiv-1654679048replbq, #ygrps-yiv-1654679048 li.ygrps-yiv-1654679048replbq, #ygrps-yiv-1654679048 div.ygrps-yiv-1654679048replbq
margin:3.0pt;
font-size:12.0pt;
#ygrps-yiv-1654679048 p.ygrps-yiv-1654679048ad, #ygrps-yiv-1654679048 li.ygrps-yiv-1654679048ad, #ygrps-yiv-1654679048 div.ygrps-yiv-1654679048ad
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-1654679048 p.ygrps-yiv-1654679048underline, #ygrps-yiv-1654679048 li.ygrps-yiv-1654679048underline, #ygrps-yiv-1654679048 div.ygrps-yiv-1654679048underline
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-1654679048 span.ygrps-yiv-1654679048yshortcuts
#ygrps-yiv-1654679048 p.ygrps-yiv-1654679048ad1, #ygrps-yiv-1654679048 li.ygrps-yiv-1654679048ad1, #ygrps-yiv-1654679048 div.ygrps-yiv-1654679048ad1
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-1654679048 p.ygrps-yiv-1654679048ad2, #ygrps-yiv-1654679048 li.ygrps-yiv-1654679048ad2, #ygrps-yiv-1654679048 div.ygrps-yiv-1654679048ad2
margin-right:0in;
margin-bottom:7.5pt;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-1654679048 p.ygrps-yiv-1654679048underline1, #ygrps-yiv-1654679048 li.ygrps-yiv-1654679048underline1, #ygrps-yiv-1654679048 div.ygrps-yiv-1654679048underline1
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-1654679048 span.ygrps-yiv-1654679048yshortcuts1
font-family:“Verdana”, “sans-serif”;
font-weight:bold;}
#ygrps-yiv-1654679048 span.ygrps-yiv-1654679048yshortcuts2
font-weight:normal;}
#ygrps-yiv-1654679048 span.ygrps-yiv-1654679048EmailStyle34
font-family:“Calibri”, “sans-serif”;
color:#1F497D;}
#ygrps-yiv-1654679048 .ygrps-yiv-1654679048MsoChpDefault
font-size:10.0pt;}
margin:1.0in 1.0in 1.0in 1.0in;}
#ygrps-yiv-1654679048 div.ygrps-yiv-1654679048WordSection1
font-family:Symbol;}
font-family:Wingdings;}
#ygrps-yiv-1654679048 ol
{margin-bottom:0in;}
#ygrps-yiv-1654679048 ul
Can’t answer your direct question, but I can make a suggestion that MIGHT help…Can you put code for a timer to not enable the button for printing until after x seconds from generation? Do you know about how long it takes for the XML to generate?
We have some custom code on a report to add information to an XML file to use in a crystal report.
What happens is the user generates the file, and the prints with another button.
We are experiencing errors when the user clicks Print before the XML finishes generating.
Does anyone know of a way to tell if a XML generation is complete or not? Would there be a way to tie into the system monitor to find this out?
