My question is the same as my title. - I have this scenario… I am processing an assembly order in my assembly department. A nearly completed assembly thread galls up and I have to cut it open to remove internal components (salvage the parts). I nonconform and DMR the Assembly part - not the components. I need to cut it open so I create a job with a dummy part number that will retrieve all the components and allow them to be returned to inventory. I retrieve the parts after the rework, and receive each component through job receipt to salvage.
When I sent the assembly to DMR, did Kinetic (Previously EPICOR) remove the assembly components from the job also? When I receive them back into inventory, does Kinetic know where they are from?
My assumption is no, because I use lot control and I may have multiple component lots on an assembly order and I am not nonconforming a specific lot number of each component. Looking only for some clarity so I know what to expect when I get into the test environment with this. Should I bother with it?
