Does Kinetic have File > Recents lists?
We just got our Kinetic 2022.2.5 test environment created, and I’m starting to kick the tires. One of the features our folks use a lot in the classic UI is the File > Recents list to move between records. It’s very convenient.
Does something like that exist in the Kinetic UI, since there is no more ‘File’ tab?
The closest I could find is the down carat next to Jobs on the breadcrumb path, but it shows the full list instead of recents.
Oh, and 2022.2 removed the Kinetic Feedback flyout from the regular user pages. It’s only found in App Studio now.
I don’t think so (if it exists, I haven’t been able to find it). I could have sworn somebody wrote an idea about this but I can’t find it (the word recent doesn’t turn up anything related in the search results). There is this other idea that is somewhat related but the general functionality isn’t covered, only time phase. https://epicor-manufacturing.ideas.aha.io/ideas/KNTC-I-2698
I don’t even have that in classic! Is it an option somewhere? Or a license issue… Can’t find any info on it anywhere.
You won’t see it unless you’ve opened multiple records in the same form, then it just appears. I don’t think there is anything you have to do to make it work that way.
Oh it clears it after each session. Thanks.
Yeah I don’t see anything in the Kinetic screens either. Its in the memory, not the database. So they probably haven’t programmed it into Kinetic yet…
I just added an IDEA for it, but have no votes left. Please vote & comment on the thread if you’d like it as well!
https://epicor-manufacturing.ideas.aha.io/ideas/KNTC-I-2992
Give back ‘Recents’ functionality like we had in the Classic UI
One of the features our folks use a lot in the Classic UI is the File > Recents list to quickly move between recently opened records. This functionality missing in the Kinetic UI.
