Does this function exist?
Corrected version:
dim recselected as boolean
dim showsearch as boolean = true
dim whereclause as string = "Key4 = '" & txtepicustom11.text &"'"
dim multirecords as boolean = true
dim i as integer
dim max as double
dim parameter as string
'// "your searchadapter" multiselect shoud be true and the "showsearch"
must be false ( i don't know what happens if you select something)
if recselected
i =1
max = 0
while i <= dsSearch.Tables(0).Rows.count()-1
if max < dsSearch.Tables(0).Rows(i)("key5")
max = dsSearch.Tables(0).Rows(i)("key5")
end if
i = i + 1
end while
else
max = 1
end if
'// for feedback
parameter = max
MessageBox.Show(parameter, "Value", MessageBoxButtons.OK,
MessageBoxIcon.Error)
> I can't get it to work but how about this?
> dim i as integer
> dim max as double
> if recselected
> i =0
> max = 0
> if max > dsSearch.Tables(0).Rows(i)("key5")
> end if
> i = i + 1
> end while
> else
> max = 1
> end if
> max is the maximum value of key 5
> Matt Barron schreef:
>> numeric
>> ________________________________
>> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf
>> Of Fons van der Beek
>> Sent: Monday, August 27, 2007 11:48 AM
>> To: vantage@yahoogroups.com
>> Subject: Re: [Vantage] Re: Does this function exist?
>> is key5 a numeric field of a textfield?
>>> Ok - here are my variable declarations before I call the search
>>> function. I already want the list to be filtered by what is in Key4
>>> already on the form.
>>> If I want it to sort by Key5 and have it sort by the highest value in
>>> that column, would it look like "dim whereclause as string = BY key5"
>>> In addition, is there a way I can have it search by both what is in
>> Key4
>>> (as shown above) and this new function that youre talking about?
>>> Matt
>>> From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
>> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
>> Behalf
>>> Of bw2868bond
>>> Sent: Monday, August 27, 2007 11:05 AM
>>> To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
>>> Subject: [Vantage] Re: Does this function exist?
>>> The BY keyword in a where clause orders the data returned like the
>>> SQL OrderBy, The only issue is I don't think it works on all fields.
>>> You can try it and see.
>>> bw
>>> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
>> <mailto:vantage%40yahoogroups.com> ,
>>> "Matt Barron" <mbarron@...> wrote:
>>>> If the dataset can be sorted after filled, that would be awesome.
>>> That
>>>> would make everything so much easier.
>>>> What is a "BY" keyword?
>>>> If either the dataset can be sorted or if the whereclause can be
>>> set to
>>>> the max value - this would be a piece of cake...
>>>> Anyone know if that is possible?
>>> Behalf
>>>> Of bw2868bond
>>>> Sent: Monday, August 27, 2007 10:51 AM
>>>> A couple random thoughts....
>>>> Can the dataset be sorted after filled?
>>>> Can the whereclause Use the BY keyword to sort the data and then
>>>> select first row?
>>>> Can the whereclause select only Max value?
>>>> bw
>>>> "dub554" <mbarron@> wrote:
>>>>> Is there a VB function that will automatically find the highest
>>>> value
>>>>> in a particular column after a searchfunction.listlookup function
>>> is
>>>>> called?
>>>>> I'd like to be able to find the highest value of this column in
>>> the
>>>>> search....
>>>>> Thanks for any input
>>>> [Non-text portions of this message have been removed]
>>> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
>> have already linked your email address to a yahoo id to enable access. )
>>> (1) To access the Files Section of our Yahoo!Group for Report Builder
>> and Crystal Reports and other 'goodies', please goto:
>> http://groups.yahoo.com/group/vantage/files/.
>> <http://groups.yahoo.com/group/vantage/files/.>
>>> (2) To search through old msg's goto:
>> http://groups.yahoo.com/group/vantage/messages
>> <http://groups.yahoo.com/group/vantage/messages>
>>> (3) To view links to Vendors that provide Vantage services goto:
>> http://groups.yahoo.com/group/vantage/links
>> <http://groups.yahoo.com/group/vantage/links>
>>> Yahoo! Groups Links
>> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to enable access. )
>> (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.
>> (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
>> (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/links
>> Yahoo! Groups Links
Is there a VB function that will automatically find the highest value
in a particular column after a searchfunction.listlookup function is
called?
I'd like to be able to find the highest value of this column in the
search....
select first row?
bw
value
> called?
> search....
If the dataset can be sorted after filled, that would be awesome. That
If either the dataset can be sorted or if the whereclause can be set to
Of bw2868bond
select first row?
bw
value
> called?
> search....
bw
That
set to
Behalf
> Of bw2868bond
> select first row?
> bw
> value
is
> > called?
the
> > search....
that column, would it look like "dim whereclause as string = BY key5" ?
In addition, is there a way I can have it search by both what is in Key4
Matt
Of bw2868bond
bw
That
set to
Behalf
> Of bw2868bond
> select first row?
> bw
> value
is
> > called?
the
> > search....
> Matt
> Of bw2868bond
> bw
> That
> set to
> Behalf
>> Of bw2868bond
>> select first row?
>> bw
>> value
> is
>>> called?
> the
>>> search....
> Yahoo! Groups Links
numeric
Key4
> Matt
Behalf
> Of bw2868bond
> bw
> That
> set to
> Behalf
>> Of bw2868bond
>> select first row?
>> bw
>> value
> is
>>> called?
> the
>>> search....
> Yahoo! Groups Links
dim i as integer
dim max as double
if recselected
i =0
max = 0
end if
i = i + 1
end while
else
max = 1
end if
> numeric
> Key4
>> Matt
> Behalf
>> Of bw2868bond
>> bw
>> That
>> set to
>> Behalf
>>> Of bw2868bond
>>> select first row?
>>> bw
>>> value
>> is
>>>> called?
>> the
>>>> search....
>> Yahoo! Groups Links
> Yahoo! Groups Links
