Dollars to text
Has anyone ever had the need to print the text version of a dollar amount on a report? This would be similar to a check ex. “One Thousand and Fifty Dollars” for $1050.00. I need to mimic this functionality. Actually now that I think of it maybe I can copy the check printing report definition and build off of that. But I will take any suggestions anyone can offer :).
thanks in advance
https://social.msdn.microsoft.com/Forums/vstudio/en-US/0b1dec9c-61e9-4544-8134-bda1264a21a4/how-to-convert-number-into-words-in-c?forum=csharpgeneral
don´t know if it will help you, but I have the following code implemented. It is used to convert an invoice Total amount into text including decimals. You will find some Spanish words such as variable names, numbers, etc… but if necessary it wouldn´t be hard to cutomize or translate.
public sealed class Numalet
    #region Miembros estáticos
    private const int UNI = 0, DIECI = 1, DECENA = 2, CENTENA = 3;
    private static string[,] _matriz = new string[CENTENA + 1, 10]
            {null," uno", " dos", " tres", " cuatro", " cinco", " seis", " siete", " ocho", " nueve"},
            {" diez"," once"," doce"," trece"," catorce"," quince"," dieciséis"," diecisiete"," dieciocho"," diecinueve"},
            {null,null,null," treinta"," cuarenta"," cincuenta"," sesenta"," setenta"," ochenta"," noventa"},
            {null,null,null,null,null," quinientos",null," setecientos",null," novecientos"}
    private const Char sub = (Char)26;
    //Cambiar acá si se quiere otro comportamiento en los métodos de clase
    public const String SeparadorDecimalSalidaDefault = "con";
    public const String MascaraSalidaDecimalDefault = "00'/100.-'";
    public const Int32 DecimalesDefault = 2;
    public const Boolean LetraCapitalDefault = false;
    public const Boolean ConvertirDecimalesDefault = false;
    public const Boolean ApocoparUnoParteEnteraDefault = false;
    public const Boolean ApocoparUnoParteDecimalDefault = false;
    #endregion
    #region Propiedades
    private Int32 _decimales = DecimalesDefault;
    private CultureInfo _cultureInfo = CultureInfo.CurrentCulture;
    private String _separadorDecimalSalida = SeparadorDecimalSalidaDefault;
    private Int32 _posiciones = DecimalesDefault;
    private String _mascaraSalidaDecimal, _mascaraSalidaDecimalInterna = MascaraSalidaDecimalDefault;
    private Boolean _esMascaraNumerica = true;
    private Boolean _letraCapital = LetraCapitalDefault;
    private Boolean _convertirDecimales = ConvertirDecimalesDefault;
    private Boolean _apocoparUnoParteEntera = false;
    private Boolean _apocoparUnoParteDecimal;
    /// <summary>
    /// Indica la cantidad de decimales que se pasarán a entero para la conversión
    /// </summary>
    /// <remarks>Esta propiedad cambia al cambiar MascaraDecimal por un valor que empieze con '0'</remarks>
    public Int32 Decimales
        get { return _decimales; }
        set
            if (value > 10) throw new ArgumentException(value.ToString() + " excede el número máximo de decimales admitidos, solo se admiten hasta 10.");
            _decimales = value;
    /// <summary>
    /// Objeto CultureInfo utilizado para convertir las cadenas de entrada en números
    /// </summary>
    public CultureInfo CultureInfo
        get { return _cultureInfo; }
        set { _cultureInfo = value; }
    /// <summary>
    /// Indica la cadena a intercalar entre la parte entera y la decimal del número
    /// </summary>
    public String SeparadorDecimalSalida
        get { return _separadorDecimalSalida; }
        set
            _separadorDecimalSalida = value;
            //Si el separador decimal es compuesto, infiero que estoy cuantificando algo,
            //por lo que apocopo el "uno" convirtiéndolo en "un"
            if (value.Trim().IndexOf(" ") > 0)
                _apocoparUnoParteEntera = true;
            else _apocoparUnoParteEntera = false;
    /// <summary>
    /// Indica el formato que se le dara a la parte decimal del número
    /// </summary>
    public String MascaraSalidaDecimal
        get
            if (!String.IsNullOrEmpty(_mascaraSalidaDecimal))
                return _mascaraSalidaDecimal;
            else return "";
        set
            //determino la cantidad de cifras a redondear a partir de la cantidad de '0' o '#'
            //que haya al principio de la cadena, y también si es una máscara numérica
            int i = 0;
            while (i < value.Length
                && (value[i] == '0')
                    | value[i] == '#')
                i++;
            _posiciones = i;
            if (i > 0)
                _decimales = i;
            else _esMascaraNumerica = false;
            _mascaraSalidaDecimal = value;
            if (_esMascaraNumerica)
                _mascaraSalidaDecimalInterna = value.Substring(0, _posiciones) + "'"
                    + value.Substring(_posiciones)
                    .Replace("''", sub.ToString())
                    .Replace("'", String.Empty)
                    .Replace(sub.ToString(), "'") + "'";
            else
                    .Replace(sub.ToString(), "'");
    /// <summary>
    /// Indica si la primera letra del resultado debe estár en mayúscula
    /// </summary>
    public Boolean LetraCapital
        get { return _letraCapital; }
        set { _letraCapital = value; }
    /// <summary>
    /// Indica si se deben convertir los decimales a su expresión nominal
    /// </summary>
    public Boolean ConvertirDecimales
        get { return _convertirDecimales; }
        set
            _convertirDecimales = value;
            _apocoparUnoParteDecimal = value;
            if (value)
            {// Si la máscara es la default, la borro
                if (_mascaraSalidaDecimal == MascaraSalidaDecimalDefault)
                    MascaraSalidaDecimal = "";
            else if (String.IsNullOrEmpty(_mascaraSalidaDecimal))
                //Si no hay máscara dejo la default
                MascaraSalidaDecimal = MascaraSalidaDecimalDefault;
    /// <summary>
    /// Indica si de debe cambiar "uno" por "un" en las unidades.
    /// </summary>
    public Boolean ApocoparUnoParteEntera
        get { return _apocoparUnoParteEntera; }
        set { _apocoparUnoParteEntera = value; }
    /// <summary>
    /// Determina si se debe apococopar el "uno" en la parte decimal
    /// </summary>
    /// <remarks>El valor de esta propiedad cambia al setear ConvertirDecimales</remarks>
    public Boolean ApocoparUnoParteDecimal
        get { return _apocoparUnoParteDecimal; }
        set { _apocoparUnoParteDecimal = value; }
    #endregion
    #region Constructores
    public Numalet()
        SeparadorDecimalSalida = SeparadorDecimalSalidaDefault;
        LetraCapital = LetraCapitalDefault;
        ConvertirDecimales = _convertirDecimales;
    public Numalet(Boolean ConvertirDecimales, String MascaraSalidaDecimal, String SeparadorDecimalSalida, Boolean LetraCapital)
        if (!String.IsNullOrEmpty(MascaraSalidaDecimal))
            this.MascaraSalidaDecimal = MascaraSalidaDecimal;
        if (!String.IsNullOrEmpty(SeparadorDecimalSalida))
            _separadorDecimalSalida = SeparadorDecimalSalida;
        _letraCapital = LetraCapital;
        _convertirDecimales = ConvertirDecimales;
    #endregion
    #region Conversores de instancia
    public String ToCustomCardinal(Double Numero)
    { return Convertir((Decimal)Numero, _decimales, _separadorDecimalSalida, _mascaraSalidaDecimalInterna, _esMascaraNumerica, _letraCapital, _convertirDecimales, _apocoparUnoParteEntera, _apocoparUnoParteDecimal); }
    public String ToCustomCardinal(String Numero)
        Double dNumero;
        if (Double.TryParse(Numero, NumberStyles.Float, _cultureInfo, out dNumero))
            return ToCustomCardinal(dNumero);
        else throw new ArgumentException("'" + Numero + "' no es un número válido.");
    public String ToCustomCardinal(Decimal Numero)
    { return ToCardinal((Numero)); }
    public String ToCustomCardinal(Int32 Numero)
    { return Convertir((Decimal)Numero, 0, _separadorDecimalSalida, _mascaraSalidaDecimalInterna, _esMascaraNumerica, _letraCapital, _convertirDecimales, _apocoparUnoParteEntera, false); }
    #endregion
    #region Conversores estáticos
    public static String ToCardinal(Int32 Numero)
        return Convertir((Decimal)Numero, 0, null, null, true, LetraCapitalDefault, ConvertirDecimalesDefault, ApocoparUnoParteEnteraDefault, ApocoparUnoParteDecimalDefault);
    public static String ToCardinal(Double Numero)
        return ToCardinal((Decimal)Numero);
    public static String ToCardinal(String Numero, CultureInfo ReferenciaCultural)
        Double dNumero;
        if (Double.TryParse(Numero, NumberStyles.Float, ReferenciaCultural, out dNumero))
            return ToCardinal(dNumero);
    public static String ToCardinal(String Numero)
        return Numalet.ToCardinal(Numero, CultureInfo.CurrentCulture);
    public static String ToCardinal(Decimal Numero)
        return Convertir(Numero, DecimalesDefault, SeparadorDecimalSalidaDefault, MascaraSalidaDecimalDefault, true, LetraCapitalDefault, ConvertirDecimalesDefault, ApocoparUnoParteEnteraDefault, ApocoparUnoParteDecimalDefault);
    #endregion
    private static String Convertir(Decimal Numero, Int32 Decimales, String SeparadorDecimalSalida, String MascaraSalidaDecimal, Boolean EsMascaraNumerica, Boolean LetraCapital, Boolean ConvertirDecimales, Boolean ApocoparUnoParteEntera, Boolean ApocoparUnoParteDecimal)
        Int64 Num;
        Int32 terna, centenaTerna, decenaTerna, unidadTerna, iTerna;
        String cadTerna;
        StringBuilder Resultado = new StringBuilder();
        Num = (Int64)Math.Abs(Numero);
        if (Num >= 1000000000000 || Num < 0) throw new ArgumentException("El número '" + Numero.ToString() + "' excedió los límites del conversor: [0;1.000.000.000.000)");
        if (Num == 0)
            Resultado.Append(" cero");
        else
            iTerna = 0;
            while (Num > 0)
                iTerna++;
                cadTerna = String.Empty;
                terna = (Int32)(Num % 1000);
                centenaTerna = (Int32)(terna / 100);
                decenaTerna = terna % 100;
                unidadTerna = terna % 10;
                if ((decenaTerna > 0) && (decenaTerna < 10))
                    cadTerna = _matriz[UNI, unidadTerna] + cadTerna;
                else if ((decenaTerna >= 10) && (decenaTerna < 20))
                    cadTerna = cadTerna + _matriz[DIECI, unidadTerna];
                else if (decenaTerna == 20)
                    cadTerna = cadTerna + " veinte";
                else if ((decenaTerna > 20) && (decenaTerna < 30))
                    cadTerna = " veinti" + _matriz[UNI, unidadTerna].Substring(1);
                else if ((decenaTerna >= 30) && (decenaTerna < 100))
                    if (unidadTerna != 0)
                        cadTerna = _matriz[DECENA, (Int32)(decenaTerna / 10)] + " y" + _matriz[UNI, unidadTerna] + cadTerna;
                    else
                        cadTerna += _matriz[DECENA, (Int32)(decenaTerna / 10)];
                switch (centenaTerna)
                    case 1:
                        if (decenaTerna > 0) cadTerna = " ciento" + cadTerna;
                        else cadTerna = " cien" + cadTerna;
                        break;
                    case 5:
                    case 7:
                    case 9:
                        cadTerna = _matriz[CENTENA, (Int32)(terna / 100)] + cadTerna;
                        break;
                    default:
                        if ((Int32)(terna / 100) > 1) cadTerna = _matriz[UNI, (Int32)(terna / 100)] + "cientos" + cadTerna;
                        break;
                //Reemplazo el 'uno' por 'un' si no es en las únidades o si se solicító apocopar
                if ((iTerna > 1 | ApocoparUnoParteEntera) && decenaTerna == 21)
                    cadTerna = cadTerna.Replace("veintiuno", "veintiún");
                else if ((iTerna > 1 | ApocoparUnoParteEntera) && unidadTerna == 1 && decenaTerna != 11)
                    cadTerna = cadTerna.Substring(0, cadTerna.Length - 1);
                //Acentúo 'veintidós', 'veintitrés' y 'veintiséis'
                else if (decenaTerna == 22) cadTerna = cadTerna.Replace("veintidos", "veintidós");
                else if (decenaTerna == 23) cadTerna = cadTerna.Replace("veintitres", "veintitrés");
                else if (decenaTerna == 26) cadTerna = cadTerna.Replace("veintiseis", "veintiséis");
                //Completo miles y millones
                switch (iTerna)
                    case 3:
                        if (Numero < 2000000) cadTerna += " millón";
                        else cadTerna += " millones";
                        break;
                    case 2:
                    case 4:
                        if (terna > 0) cadTerna += " mil";
                        break;
                Resultado.Insert(0, cadTerna);
                Num = (Int32)(Num / 1000);
            } //while
        //Se agregan los decimales si corresponde
        if (Decimales > 0)
            Resultado.Append(" " + SeparadorDecimalSalida + " ");
            Int32 EnteroDecimal = (Int32)Math.Round((Double)(Numero - (Int64)Numero) * Math.Pow(10, Decimales), 0);
            if (ConvertirDecimales)
                Boolean esMascaraDecimalDefault = MascaraSalidaDecimal == MascaraSalidaDecimalDefault;
                Resultado.Append(Convertir((Decimal)EnteroDecimal, 0, null, null, EsMascaraNumerica, false, false, (ApocoparUnoParteDecimal && !EsMascaraNumerica/*&& !esMascaraDecimalDefault*/), false) + " "
                    + (EsMascaraNumerica ? "" : MascaraSalidaDecimal));
            else
                if (EsMascaraNumerica) Resultado.Append(EnteroDecimal.ToString(MascaraSalidaDecimal));
                else Resultado.Append(EnteroDecimal.ToString() + " " + MascaraSalidaDecimal);
        //Se pone la primer letra en mayúscula si corresponde y se retorna el resultado
        if (LetraCapital)
            return Resultado[1].ToString().ToUpper() + Resultado.ToString(2, Resultado.Length - 2);
        else
            return Resultado.ToString().Substring(1);
Thanks Mark!!
The fun part is going to be that it is for our China company!! I’m sure this will be very helpful.
thanks again
I wrote this a while back to use in SSRS from a partial solution I found somewhere, just stick it in the “Code” portion of the Report and call it in the Expression Editor with
Code.NumberToTextD(1234.55) 'Your Report Variable can go here Too (must be a double use the CDbl function if needed
Its for “dollars” but you can replace the hard coded words in the function to suit your needs. Note it doesn’t convert the decimal portion to text (Didn’t deem it necesary it justs says One Hundred Dollars and 23 cents)
Public Shared Function NumberToTextD(ByVal n As Double) As String
        Dim s As String
        s = FormatNumber(Math.Round((Math.Ceiling(n) - n), 2), 2).ToString().Split(".")(1) & " cents"
        Return NumberToText(Math.Floor(n)) & " dollars and " & s
    End Function
Shared Function NumberToText(ByVal n As Integer) As String
        Select Case n
            Case 0
                Return "zero"
            Case 1 To 19
                Dim arr() As String = {"One", "Two", "Three", "Four", "Five", "Six", "Seven",
    "Eight", "Nine", "Ten", "Eleven", "Twelve", "Thirteen", "Fourteen",
      "Fifteen", "Sixteen", "Seventeen", "Eighteen", "Nineteen"}
                Return arr(n - 1) & " "
            Case 20 To 99
                Dim arr() As String = {"Twenty", "Thirty", "Forty", "Fifty", "Sixty", "Seventy", "Eighty", "Ninety"}
                Return arr(n \ 10 - 2) & " " & NumberToText(n Mod 10)
            Case 100 To 199
                Return "One Hundred " & NumberToText(n Mod 100)
            Case 200 To 999
                Return NumberToText(n \ 100) & "Hundred " & NumberToText(n Mod 100)
            Case 1000 To 1999
                Return "One Thousand " & NumberToText(n Mod 1000)
            Case 2000 To 999999
                Return NumberToText(n \ 1000) & "Thousand " & NumberToText(n Mod 1000)
            Case 1000000 To 1999999
                Return "One Million " & NumberToText(n Mod 1000000)
            Case 1000000 To 999999999
                Return NumberToText(n \ 1000000) & "Million " & NumberToText(n Mod 1000000)
            Case 1000000000 To 1999999999
                Return "One Billion " & NumberToText(n Mod 1000000000)
            Case Else
                Return NumberToText(n \ 1000000000) & "Billion " _
        End Select
    End Function
