Drop Ship all Releases
Other than setting the Part Maint check boxes for BTO and Drop Ship is there a way in a Sales Order to set all Releases to Drop Ship?
i.e. Per Order, set all Release lines at once instead of having to scroll through and set individually.
Thanks in advance.
Todd
I believe that the only place to do this is in the Order Release, because that is also where you set the Purchase Direct. I can see where this could be a challenge if you have a large order with lots of lines that are all purchase direct. That sounds like an Enhancement Request that you could submit on the Epicor Ideas webpage. Until then, you could also probably add a UD “Dropship” Checkbox to the Order Header, and then a BPM that would update all releases when that checkbox is selected.
