I've been looking for a way to run the table dump so that it can be run from a batch file non-interactively. I've called into support a few times but never got anywhere with them. After doing some searching on the internet, I've managed to come up with the following code:
Command Line
C:\> mbpro G:\DbOrig\mfgsys -1 -p J:\Epicor\OpenEdge\DumpLoadKit8\AlfeDump.p
DEFINE VARIABLE cmd AS CHARACTER NO-UNDO.
FOR EACH mfgsys._file WHERE _File-Number>0 AND _dump-name<>"" AND LENGTH(_dump-name)>2 NO-LOCK:
cmd = "G:\DbDump\Data2\" + _Dump-name + ".p".
OUTPUT TO VALUE(cmd).
PUT UNFORMATTED "DEFINE VARIABLE len AS INTEGER NO-UNDO INITIAL 0." SKIP.
PUT UNFORMATTED "DEFINE VARIABLE ctr AS INTEGER NO-UNDO INITIAL 0." SKIP.
PUT UNFORMATTED "OUTPUT TO G:\DbDump\Data2\" + _dump-name + ".d." SKIP.
PUT UNFORMATTED "FOR EACH " _file-name " NO-LOCK:" SKIP.
PUT UNFORMATTED "ctr = ctr + 1." SKIP.
PUT UNFORMATTED "EXPORT " _file-name "." SKIP.
PUT UNFORMATTED "END." SKIP.
PUT UNFORMATTED "PUT UNFORMATTED '.' SKIP." SKIP.
PUT UNFORMATTED "len = SEEK(OUTPUT)." SKIP.
PUT UNFORMATTED "PUT UNFORMATTED 'PSC' SKIP." SKIP.
PUT UNFORMATTED "PUT UNFORMATTED 'filename=" + _file-name + "' SKIP." SKIP.
PUT UNFORMATTED "PUT UNFORMATTED 'records=' STRING(ctr,'9999999999999' ) SKIP." SKIP.
PUT UNFORMATTED "PUT UNFORMATTED 'ldbname=mfgsys' SKIP." SKIP.
PUT UNFORMATTED "PUT UNFORMATTED 'timestamp=2011/11/11-11:11:11' SKIP." SKIP.
PUT UNFORMATTED "PUT UNFORMATTED 'numformat=44,46' SKIP." SKIP.
PUT UNFORMATTED "PUT UNFORMATTED 'dateformat=mdy-1950' SKIP." SKIP.
PUT UNFORMATTED "PUT UNFORMATTED 'map=NO-MAP' SKIP." SKIP.
PUT UNFORMATTED "PUT UNFORMATTED 'cpstream=ISO8859-1' SKIP." SKIP.
PUT UNFORMATTED "PUT UNFORMATTED STRING(len,'9999999999') SKIP." SKIP.
PUT UNFORMATTED "OUTPUT CLOSE." SKIP.
PUT UNFORMATTED "RETURN." SKIP.
OUTPUT CLOSE.
RUN VALUE(CMD).
DOS SILENT VALUE('DEL "' + cmd + '"').
END.
QUIT.
RETURN.
When the corresponding dump files are compared, ignoring the trailer information at the end of the files, the files are identical. The only difference I can detect is that the timestamp line is different, for obvious reasons, however, this code runs in approximately 1/5 the time that the dumptables.r code does. Does anyone know why this is? What does Epicor's code do that mine doesn't?
Command Line
OUTPUT CLOSE.
RUN VALUE(CMD).
END.
QUIT.
RETURN.
