Duplicated Entry in Customer Maintenance
I have several companies in Epicor, when I want to create a new customer in one of companies, no matter what customer ID I type in, there always be an error said: there is a duplicated entry.
I checked all companies database, we don’t have that record. and I checked all BPM and Customization are the same in all companies.
it is wired that only this error happened in one company.
Business Layer Exception
This is a duplicate entry of an existing record
Error Detail
Description: This is a duplicate entry of an existing record
Program: Epicor.Ice.dll
Method: CreateRow
Line Number: 1035
Column Number: 17
Table: Customer
Server Trace Stack: at Ice.TablesetBound3.CreateRow(IceDataContext dataContext, Int32 tableNum, IIceTable table, IceRow newTablesetRow, TablesetProfilingCollector parentTraceCollector) in c:\_Releases\ICE\3.1.400.4\source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 1035 at Ice.TablesetBound3.WriteTable(IceDataContext dataContext, Int32 tableIndex, IIceTable table, TablesetProfilingCollector parentTraceCollector) in c:_Releases\ICE\3.1.400.4\source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 884
at Ice.TablesetBound3.InnerUpdate(IceDataContext dataContext, TFullTableset tableset) in c:\_Releases\ICE\3.1.400.4\source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 796 at Erp.Services.BO.CustomerSvc.Update(CustomerTableset& ds) in c:\_Releases\ERP\UD10.1.400.4\Source\Server\Services\BO\Customer\Customer.Designer.cs:line 6524 at Epicor.Customization.Bpm.MethodCustomizationBase23.RunDirectives(TParam parameters) in c:_Releases\ICE\3.1.400.4\source\Server\Internal\Lib\Epicor.Customization.BPM\MethodCustomizationBase2.cs:line 218
at Epicor.Customization.Bpm.CustomizationBase23.Execute(TParam parameters) in c:\_Releases\ICE\3.1.400.4\source\Server\Internal\Lib\Epicor.Customization.BPM\CustomizationBase2.cs:line 77 at Epicor.Customization.Bpm.BO01B6B638B55C4D1B9302352664E5AB81.CustomerSvcCustomization.Update(CustomerTableset& ds) at Erp.Services.BO.CustomerSvcFacade.Update(CustomerTableset& ds) in c:\_Releases\ERP\UD10.1.400.4\Source\Server\Services\BO\Customer\CustomerSvcFacade.cs:line 686 at SyncInvokeUpdate(Object , Object[] , Object[] ) at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) at Epicor.Hosting.OperationBoundInvoker.InnerInvoke(Object instance, Func2 func) in c:_Releases\ICE\3.1.400.4\source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 59
at Epicor.Hosting.OperationBoundInvoker.Invoke(Object instance, Func2 func) in c:\_Releases\ICE\3.1.400.4\source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 28 at Epicor.Hosting.Wcf.EpiOperationInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) in c:\_Releases\ICE\3.1.400.4\source\Framework\Epicor.System\Hosting\Wcf\EpiOperationInvoker.cs:line 23 at System.ServiceModel.Dispatcher.DispatchOperationRuntime.InvokeBegin(MessageRpc& rpc) at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage5(MessageRpc& rpc) at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage11(MessageRpc& rpc) at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet) at System.ServiceModel.Dispatcher.ChannelHandler.DispatchAndReleasePump(RequestContext request, Boolean cleanThread, OperationContext currentOperationContext) at System.ServiceModel.Dispatcher.ChannelHandler.HandleRequest(RequestContext request, OperationContext currentOperationContext) at System.ServiceModel.Dispatcher.ChannelHandler.AsyncMessagePump(IAsyncResult result) at System.ServiceModel.Dispatcher.ChannelHandler.OnAsyncReceiveComplete(IAsyncResult result) at System.Runtime.Fx.AsyncThunk.UnhandledExceptionFrame(IAsyncResult result) at System.Runtime.AsyncResult.Complete(Boolean completedSynchronously) at System.ServiceModel.Channels.SecurityChannelListener1.ReceiveItemAndVerifySecurityAsyncResult`2.InnerTryReceiveCompletedCallback(IAsyncResult result)
at System.ServiceModel.Channels.TransportDuplexSessionChannel.TryReceiveAsyncResult.OnReceive(IAsyncResult result)
at System.ServiceModel.Channels.SynchronizedMessageSource.ReceiveAsyncResult.OnReceiveComplete(Object state)
at System.ServiceModel.Channels.SessionConnectionReader.OnAsyncReadComplete(Object state)
at System.Net.LazyAsyncResult.Complete(IntPtr userToken)
at System.Net.LazyAsyncResult.ProtectedInvokeCallback(Object result, IntPtr userToken)
at System.Net.Security.NegotiateStream.ProcessFrameBody(Int32 readBytes, Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)
at System.Net.Security.NegotiateStream.ReadCallback(AsyncProtocolRequest asyncRequest)
at System.Net.AsyncProtocolRequest.CompleteRequest(Int32 result)
at System.Net.FixedSizeReader.CheckCompletionBeforeNextRead(Int32 bytes)
at System.Net.FixedSizeReader.ReadCallback(IAsyncResult transportResult)
at System.ServiceModel.Channels.ConnectionStream.IOAsyncResult.OnAsyncIOComplete(Object state)
at System.Net.Sockets.SocketAsyncEventArgs.OnCompleted(SocketAsyncEventArgs e)
at System.Net.Sockets.SocketAsyncEventArgs.FinishOperationSuccess(SocketError socketError, Int32 bytesTransferred, SocketFlags flags)
at System.Net.Sockets.SocketAsyncEventArgs.CompletionPortCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* nativeOverlapped)
at System.Threading._IOCompletionCallback.PerformIOCompletionCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* pOVERLAP)
Client Stack Trace
at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets)
at Erp.Proxy.BO.CustomerImpl.Update(CustomerDataSet ds)
at Erp.Adapters.CustomerAdapter.OnUpdate()
at Ice.Lib.Framework.EpiBaseAdapter.Update()
at Erp.UI.App.CustomerEntry.Transaction.Update() in c:_Releases\ERP\UD10.1.400.4\Source\Client\UIApps\CustomerEntry\transactions\Transaction.cs:line 3140
