So i am trying to add a parameter list in my dynamic query. but i cant seem to get the context right i keep getting this error:
Here is my current code right now:
var context = Ice.Services.ContextFactory.CreateContext<ErpContext>();
using (var svc = Ice.Assemblies.ServiceRenderer.GetService<Ice.Contracts.DynamicQuerySvcContract>(context))
Ice.Tablesets.DynamicQueryTableset dsQuery = svc.GetByID("API_MassPrintJobDrawingsPDF");
if (dsQuery != null)
Ice.Tablesets.QueryExecutionTableset dsBAQ = svc.GetQueryExecutionParameters(dsQuery);
foreach ( var jobNum in jobNumber)
dsBAQ.ExecutionParameter.Clear();
dsBAQ.ExecutionParameter[0].ParameterID = "JobNumber";
dsBAQ.ExecutionParameter[0].IsEmpty = false;
dsBAQ.ExecutionParameter[0].ParameterValue = jobNum.ToString();
dsBAQ.ExecutionParameter[0].RowMod = "A";
DataSet ListOfPDFS = svc.Execute(dsQuery,dsBAQ);
System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
at System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
at EFx.PrintJobDrawings.Implementation.CreateXMLForJobDrawingsImpl.A001_CustomCodeAction()
at EFx.PrintJobDrawings.Implementation.CreateXMLForJobDrawingsImpl.RunStep(Int32 workflowStep)
at Epicor.Functions.FunctionBase3.Run() in C:\_Releases\ICE\ICE3.2.700.0\Source\Server\Internal\Lib\Epicor.Functions.Core\FunctionBase.cs:line 90 at Epicor.Functions.FunctionBase
3.Run(TInput input) in C:_Releases\ICE\ICE3.2.700.0\Source\Server\Internal\Lib\Epicor.Functions.Core\FunctionBase.cs:line 75
at Epicor.Functions.FunctionRestAdapter2.Run(IFunctionRestHost host, JObject input) in C:\_Releases\ICE\ICE3.2.700.0\Source\Server\Internal\Lib\Epicor.Functions.Core\FunctionRestAdapter.cs:line 46 at Epicor.RESTApi.Functions.Controllers.EpicorFunctionController.Post(Boolean production, String company, String library, String function, JObject data) in C:\_Releases\ICE\ICE3.2.700.0\Source\Server\Internal\RESTApi.Plugins\Epicor.RESTApi.EFxPlugin\Controllers\EpicorFunctionController.cs:line 69 at lambda_method(Closure , Object , Object[] ) at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.<>c__DisplayClass6_2.<GetExecutor>b__2(Object instance, Object[] methodParameters) at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ExecuteAsync(HttpControllerContext controllerContext, IDictionary
2 arguments, CancellationToken cancellationToken)
— End of stack trace from previous location where exception was thrown —
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at System.Web.Http.Controllers.ApiControllerActionInvoker.d__1.MoveNext()
at System.Web.Http.Filters.ActionFilterAttribute.d__6.MoveNext()
at System.Web.Http.Filters.ActionFilterAttribute.d__5.MoveNext()
at System.Web.Http.Controllers.ActionFilterResult.d__5.MoveNext()
at System.Web.Http.Dispatcher.HttpControllerDispatcher.d__15.MoveNext()
