I’ve used Solution Management to build solutions in my development environment to install on my production environment several times successfully. However I now have an issue where it’s not working and I’m at a loss as to why. I set up several different Report Styles for GenShip for some customer specific shipping labels. I create the solution, build the solution, save the files to a location, so far so good. Next, I go to my production environment, I open Solution Management, actions, install solution. Seems to run successfully. However, when I open Report Styles, none of the Styles I added under GenShip are visible. Any ideas what I’m missing here?
Also, I’m hoping to be able to bring over some AutoPrint data directives I’ve created. Is this possible to copy over via Solution Management? I’m not sure what I should be looking for when I search as I can’t seem to find anything related to the data directives.
Thanks in advance!
Mike
