E10.1 Printing Blank Title 141442
Default printer is HP3015 using 8.5 x 11 paper as default
Sent: Tuesday, May 03, 2016 8:03 AM
Subject: [Vantage] Re: E10.1 Printing
Just a thought - could the default printer on the client workstation be set to a label size or some non-standard size? The error message seems to point to Min and Max values that makes me think paper size.
Anyone experiencing printing issues using Epicor10.1 ?
We 'Upgraded' a week ago and now users are experiencing long delays trying to select client printer and then eventually an error message box
Application Error
Exception caught in:
Ice.Lib.EpiClientLib
Error Detail
Message: An
error occurred trying to set a value of ‘-1’ in an EpiNumericEditor. The
controls EpiBinding is ‘printProps.PagePrinterResolutionX’.
Inner Exception Message: The
‘Value’ property cannot be set to a value that is outside the range determined
by the ‘MinValue’ and ‘MaxValue’ properties
Program:
Ice.Lib.EpiClientLib.dll
Method:
SetValueWithExceptionChecking
Client Stack Trace
   at
Ice.Lib.Framework.EpiNumericEditor.SetValueWithExceptionChecking(Object value)
   at
Ice.Lib.Framework.EpiNumericEditor.Table_ColumnChanged(Object sender,
DataColumnChangeEventArgs e)
   at
System.Data.DataColumnChangeEventHandler.Invoke(Object sender,
   at
System.Data.DataTable.OnColumnChanged(DataColumnChangeEventArgs e)
   at
System.Data.DataRow.set_Item(DataColumn column, Object value)
   at
Ice.Lib.Report.Datasets.SSRSProperties.PrintersRow.set_PagePrinterResolutionX(Int32
value)
   at
Ice.Lib.Report.SSRSDialogPropertiesManager.getPrinterSettings(String printerID)
   at
Ice.Lib.Report.SSRSDialogPropertiesManager.Printers_ColumnChanged(Object
sender, DataColumnChangeEventArgs e)
   at
   at
   at
   at
System.Data.DataRowView.SetColumnValue(DataColumn column, Object value)
   at
System.Data.DataRowView.set_Item(String property, Object value)
   at
Ice.Lib.Framework.EpiReportTransaction.setPrinterOptionsSSRS(String reportID,
Int32 styleNum, PrinterDialogMode mode, Boolean initializeSettings)
Inner Exception
The ‘Value’ property cannot be
set to a value that is outside the range determined by the ‘MinValue’ and
Inner Stack Trace
   at
Infragistics.Win.UltraWinEditors.UltraNumericEditor.set_Value(Object value)
   at
