E10 Calculated Field Editor
In that case I recommend using the ISNUMERIC function
something like
CASE ISNUMERIC(SUBSTIRING(PartNum,0,1) THEN ELSE ...Â
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
On Wed, Jan 28, 2015 at 9:03 AM, Bernie Walker bwalker@... [vantage] <vantage@yahoogroups.com> wrote:
Â
<div>
  <p>
The single quote vs. double quote is what got me on this one
Â
And I wanted to group PartNums that begin with a Numeral differently than ones that begin with an Alpha….
Â
Thanks.
Â
Sent: Wednesday, January 28, 2015 8:59 AM
To: Vantage
Subject: Re: [Vantage] E10 Calculated Field Editor
Â
E10 is SQL , (MSSQL) to be exact MSSQL doesn't have an IF THEN ELSE but the CASE WILL WORK just do
Â
CASE WHEN PartNum < "A" Â THEN ' ' ELSE SUBSTRING (...) END.
Â
Â
However a couple of notes, why are you comparing character "A" with a less than operator? This doesn't work well seeing as most languages take the value of A in ASCII (65) to use as a comparison which can yield funny results for example "a" is ASCII 97 meaning that A < a = true... What are you trying to do exactly? There may be better ways
Jose C Gomez
Software Engineer
E: jose@...
http://www.josecgomez.com
 Â
   Â
Â
On Wed, Jan 28, 2015 at 8:31 AM, bwalker@... [vantage] <vantage@yahoogroups.com> wrote:
Â
I am trying to do an If - Then - Else using the calculated field editor and when I select that condition, it is giving me (case when then else end)
Â
I don't see how that is equivalent since you cant use comparison symbols in a when statement ???
Â
Is there not a true If-Then-Else condition available?
Â
What I want is:
Â
if (PartNum < "A") Then "Â " Else substring(PartNum,0 ,2 )
Â
</div>
<div style="color:#fff;min-height:0;"></div>
What I want is:
if (PartNum < "A") Then "  " Else substring(PartNum,0 ,2 )
Jose C Gomez
Software Engineer
Â
<div>
  <p></p><p><span>I am trying to do an If - Then - Else using the calculated field editor and when I select that condition, it is giving me (case when  then  else  end)</span></p><p><span><br></span></p><p><span>I don&#39;t see how that is equivalent since you cant use comparison symbols in a when statement ???</span></p><p><span><br></span></p><p><span>Is there not a true If-Then-Else condition available?</span></p><p><span><br></span></p><p><span>What I want is:</span></p><p><span><br></span></p><p><span>if (PartNum &lt; &quot;A&quot;) Then &quot;  &quot; Else substring(PartNum,0 ,2 )</span></p><p></p>
</div>
Thanks.
To: Vantage
CASE WHEN PartNum < "A"  THEN ' ' ELSE SUBSTRING (...) END.
Jose C Gomez
Software Engineer
What I want is:
