Hi,
Does anyone know the extent of the callContextBpmData's scope? I always thought it was confined to the method you are working in and only for the duration of the transaction. For example, you can assign callContextBpmData.ShortChar01 differently in both SalesOrder.Update and Part.Update without any conflict, and when the transaction is over and you start a new SalesOrder.Update event, you start with an empty callContextBpmData.ShortChar01.
However, someone point out to me that they set callContextBpmData values in Part.GetByID and then is able to call it with this code (VB.NET) in a customization on the Part Entry form:
Private WithEvents edvCallContextBpmData As EpiDataView
edvCallContextBpmData = CType(oTrans.EpiDataViews("CallContextBpmData"), EpiDataView)
If edvCallContextBpmData.HasRow then
If edvCallContextBpmData.dataView.Table.Columns.Contains("CheckBox01") And _ edvCallContextBpmData.dataView(edvCallContextBpmData.Row)("CheckBox01") = True Then
ejz_shape_subcontract.Visible = true
If (edvCallContextBpmData.dataView.Table.Columns.Contains("CheckBox02")) And _ edvCallContextBpmData.dataView(edvCallContextBpmData.Row)("CheckBox02") = True Then ejz_shape_subcontract.Status = StatusTypes.Stop
Else ejz_shape_subcontract.Status = StatusTypes.OK
End if
Else ejz_shape_subcontract.Visible = false
End If
End if
Does anybody know when callContextBpmData's scope is and when it gets reset?
Thanks.
On Wed, Aug 5, 2015 at 4:30 PM, bwhiteside@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p></p><p style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;background:transparent;">Hi,</p><p style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;background:transparent;">Does anyone know the extent of the callContextBpmData's scope? I always thought it was confined to the method you are working in and only for the duration of the transaction. For example, you can assign callContextBpmData.ShortChar01 differently in both SalesOrder.Update and Part.Update without any conflict, and when the transaction is over and you start a new SalesOrder.Update event, you start with an empty callContextBpmData.ShortChar01.</p><p style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;background:transparent;">However, someone point out to me that they set callContextBpmData values in Part.GetByID and then is able to call it with this code (<a rel="nofollow" target="_blank" href="http://VB.NET">VB.NET</a>) in a customization on the Part Entry form:</p><p style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;background:transparent;"><span style="margin:0px;padding:0px;outline:0px;font-weight:inherit;font-style:inherit;font-family:inherit;vertical-align:baseline;background:transparent;">Private WithEvents edvCallContextBpmData As EpiDataView<br>edvCallContextBpmData = CType(oTrans.EpiDataViews("CallContextBpmData"), EpiDataView)<br>If edvCallContextBpmData.HasRow then<span style="margin:0px;padding:0px;outline:0px;font-weight:inherit;font-style:inherit;font-family:inherit;vertical-align:baseline;background:transparent;">Â <br></span><span style="margin:0px;padding:0px;outline:0px;font-weight:inherit;font-style:inherit;font-family:inherit;vertical-align:baseline;white-space:pre-wrap;background:transparent;"> </span>If edvCallContextBpmData.dataView.Table.Columns.Contains("CheckBox01") And _<span style="margin:0px;padding:0px;outline:0px;font-weight:inherit;font-style:inherit;font-family:inherit;vertical-align:baseline;white-space:pre-wrap;background:transparent;"> </span><span style="margin:0px;padding:0px;outline:0px;font-weight:inherit;font-style:inherit;font-family:inherit;vertical-align:baseline;background:transparent;"></span>edvCallContextBpmData.dataView(edvCallContextBpmData.Row)("CheckBox01") = True Then<span style="margin:0px;padding:0px;outline:0px;font-weight:inherit;font-style:inherit;font-family:inherit;vertical-align:baseline;background:transparent;">Â <br></span><span style="margin:0px;padding:0px;outline:0px;font-weight:inherit;font-style:inherit;font-family:inherit;vertical-align:baseline;white-space:pre-wrap;background:transparent;"> </span>ejz_shape_subcontract.Visible = true<span style="margin:0px;padding:0px;outline:0px;font-weight:inherit;font-style:inherit;font-family:inherit;vertical-align:baseline;background:transparent;">Â <br></span><span style="margin:0px;padding:0px;outline:0px;font-weight:inherit;font-style:inherit;font-family:inherit;vertical-align:baseline;white-space:pre-wrap;background:transparent;"> </span>If (edvCallContextBpmData.dataView.Table.Columns.Contains("CheckBox02")) And _<span style="margin:0px;padding:0px;outline:0px;font-weight:inherit;font-style:inherit;font-family:inherit;vertical-align:baseline;white-space:pre-wrap;background:transparent;"> </span><span style="margin:0px;padding:0px;outline:0px;font-weight:inherit;font-style:inherit;font-family:inherit;vertical-align:baseline;background:transparent;"></span>edvCallContextBpmData.dataView(edvCallContextBpmData.Row)("CheckBox02") = True Then<span style="margin:0px;padding:0px;outline:0px;font-weight:inherit;font-style:inherit;font-family:inherit;vertical-align:baseline;white-space:pre-wrap;background:transparent;"> </span><span style="margin:0px;padding:0px;outline:0px;font-weight:inherit;font-style:inherit;font-family:inherit;vertical-align:baseline;background:transparent;"></span>ejz_shape_subcontract.Status = StatusTypes.Stop<span style="margin:0px;padding:0px;outline:0px;font-weight:inherit;font-style:inherit;font-family:inherit;vertical-align:baseline;background:transparent;">Â <br></span><span style="margin:0px;padding:0px;outline:0px;font-weight:inherit;font-style:inherit;font-family:inherit;vertical-align:baseline;white-space:pre-wrap;background:transparent;"> </span>Else<span style="margin:0px;padding:0px;outline:0px;font-weight:inherit;font-style:inherit;font-family:inherit;vertical-align:baseline;background:transparent;">Â </span>ejz_shape_subcontract.Status = StatusTypes.OK<span style="margin:0px;padding:0px;outline:0px;font-weight:inherit;font-style:inherit;font-family:inherit;vertical-align:baseline;background:transparent;">Â <br></span><span style="margin:0px;padding:0px;outline:0px;font-weight:inherit;font-style:inherit;font-family:inherit;vertical-align:baseline;white-space:pre-wrap;background:transparent;"> </span>End if<span style="margin:0px;padding:0px;outline:0px;font-weight:inherit;font-style:inherit;font-family:inherit;vertical-align:baseline;background:transparent;">Â <br></span><span style="margin:0px;padding:0px;outline:0px;font-weight:inherit;font-style:inherit;font-family:inherit;vertical-align:baseline;white-space:pre-wrap;background:transparent;"> </span>Else<span style="margin:0px;padding:0px;outline:0px;font-weight:inherit;font-style:inherit;font-family:inherit;vertical-align:baseline;background:transparent;">Â </span>ejz_shape_subcontract.Visible = false<span style="margin:0px;padding:0px;outline:0px;font-weight:inherit;font-style:inherit;font-family:inherit;vertical-align:baseline;background:transparent;">Â <br></span><span style="margin:0px;padding:0px;outline:0px;font-weight:inherit;font-style:inherit;font-family:inherit;vertical-align:baseline;white-space:pre-wrap;background:transparent;"> </span>End If<br>End if<br></span></p><p style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;background:transparent;">Does anybody know when callContextBpmData's scope is and when it gets reset?</p><p><span></span></p><p style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;background:transparent;"><span style="margin:0px;padding:0px;outline:0px;font-weight:inherit;font-style:inherit;font-family:inherit;vertical-align:baseline;background:transparent;">Thanks.</span></p><p><span><br></span></p><p></p> </div> <div style="color:#fff;min-height:0;"></div>
