Hi Mike,
The solution is to go to C:\Program Files (x86)\Common Files\Epicor Software Corporation\Database Manager Extensions\3.0.7\ and rename the DB Migration folder there. Then log into the Admin console and it should be good.
- Neil
Sent: Thursday, 9 April 2015 1:47 AM
Subject: [Vantage] E10 - Error message when adding new database
v10.0.700.4
From the Epicor Admin Console, when trying to add a new database I receive the following error message:
Unhandled exception has occurred in your application. If you click to continue...
Index was outside the bounds of the array.
I currently have a functioning Demo database, SSRS works fine, Epicor Education works fine, everything seems ok.
Just trying to create a new db and the error message is presented.
Anyone else encounter this?
Thanks in advance,
Mike Lowe
Director of I.T.
Connor Manufacturing Services
USA-Singapore-China-Malaysia
Phone: +1 (503) 465-3904
Cell: +1 (949) 793-3433
Web: www.ConnorMS.com<http://www.connorms.com/>
[cid:image003.jpg@...5D070]
"Celebrating 100 years of Service"
Any and all technical data identified in this communication as EAR or ITAR Restricted Information is controlled under the Export Administration Regulations (EAR) and under the International Traffic in Arms Regulations (ITAR). The EAR / ITAR restricted information
may not be exported to a foreign person, either in the United States or abroad, without a license or exemption from the U.S. Department of Commerce and/or the U.S. Department of State as it applies.
Notice:This e-mail and any attachments are confidential and are only for the use of the person to whom they are addressed. If you are not the intended recipient please advise the sender by return e-mail and delete the message and any attachments. Any use, interference with, disclosure or copying of this message or any attachments is unauthorised and prohibited. The sender does not warrant that the information is free of a virus or any other defect or error, and any views expressed herein, unless specifically indicated otherwise, are those of the individual sender.
The DH Gibson Group of Companies - http://www.gibsonshopfitters.com.au
P Please consider our shared environment before printing this communication.
