Hi All,
We are converting from v9.05.606 (progress) to v10.0 (via an intermediary v9.05.702A server).
All data seemed to convert well until we noticed that memo fields in some Crystal reports we are converting are no longer formatted as we intended.
Inspecting both systems:
In Epicor 9 (embedded <CR><LF> give structure to the field when printed):
<LineDesc>316/L 28G 020 ON 045 6
316 (L OK)
28G (.0135/.0165")
1.984"W X 4.938"L
.020" ON .045" STAGG C/C = 20% OPEN AREA
MARGINS PER DRAWING 343485 REV 1 PART NUMBER 343485
QUOTED LESS ROLLING AND ELECTROPOLISH
****WE OFFER 28GA MAX THICKNESS FOR OUR TOOLING SAME AS LAST ORDER****</LineDesc>
In Epicor 10 (one long string seemingly stripped of all non-printing characters):
<LineDesc>316/L 28G 020 ON 045 6 316 (L OK)28G (.0135/.0165")1.984"W X 4.938"L.020" ON .045" STAGG C/C = 20% OPEN AREAMARGINS PER DRAWING 343485 REV 1 PART NUMBER 343485QUOTED LESS ROLLING AND ELECTROPOLISH****WE OFFER 28GA MAX THICKNESS FOR OUR TOOLING SAME AS LAST ORDER****</LineDesc>
These examples were gathered using the E9 and E10 ICE BL tools looking at the Quote object.
This issue to me has nothing to do with Crystal in Epicor 10 – how can it format end-of-line characters which aren’t there in the raw data?
Has someone run into this already ?
Thank you in advance for any advice,
Dave Beberman
ERP Manager
Ferguson Perforating
Providence RI
The information contained in this e-mail message is intended only for the use of the individual or entity named above. If the reader of this message is not the intended recipient, or is not the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication is strictly prohibited. If you have received this message in error, please notify Ferguson Perforating immediately by telephone or reply by e-mail and then promptly delete the message. Thank-you.
