I got it. Epicor changed some stuff so you cannot make a change once a PO tied to an inter-company supplier is approved. You have to go to inter-company PO suggestions and reject it before anything can be done to it.
From: "Anthony Gercar agercar@... [vantage]" <vantage@yahoogroups.com>
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Sent: Tuesday, November 25, 2014 10:43 AM
Subject: RE: [Vantage] E10 Purchase Order Error
Sounds like you have a multi-company set-up issue.
Check 2 things…
Do a query on the IntQueOut table.
Check the multi-company log file for errors.
Sent: Tuesday, November 25, 2014 10:41 AM
Subject: [Vantage] E10 Purchase Order Error
Has anyone got this error on a PO and figured out a fix?
Record in process, unable to update.
I get this error whenever trying to unapprove a PO where the supplier is flagged as inter-company.
Ted
Ted
