E10 - Quick Searches stop working
#ygrps-yiv-927807918 P.ygrps-yiv-927807918b1e7fd89-0279-4ffe-a16a-1f1bcba0d537 { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-927807918 LI.ygrps-yiv-927807918b1e7fd89-0279-4ffe-a16a-1f1bcba0d537 { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-927807918 DIV.ygrps-yiv-927807918b1e7fd89-0279-4ffe-a16a-1f1bcba0d537 { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-927807918 TABLE.ygrps-yiv-927807918b1e7fd89-0279-4ffe-a16a-1f1bcba0d537Table { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-927807918 DIV.ygrps-yiv-927807918Section1 { }
Thank Mark,
Look forward to the feedback.
Sent: 13 February 2015 07:07
Subject: Re: [Vantage] E10 - Quick Searches stop working
Stephen I hear what you are saying but for now the only thing I am seeing as a cause and effect is that whenever we regenerate a data model without kicking people off it is around the time the quick searches stop working for those people. Its pretty consistent. I am not seeing anything on the error logs regarding memory or low calls but I will keep monitoring
Anyway it is going to brought up to the weekly Friday meeting for development to see if there is any root cause. There have been no tickets brought up on this, so it just may be that since we are in heavy development prior to go live we are seeing it as an issue, where others already on E10 may not be doing much customization in the way of adding fields.
Thanks for the feedback I will keep everyone posted if we get a definitive answer
On Thursday, February 12, 2015 8:32 PM, "Stephen Edginton stephene@... [vantage]" <vantage@yahoogroups.com> wrote:
Just a note on this, that description about being part of a different app pool is not how IIS works, if you recycle the app pool, that w3wp.exe process is killed. Users don’t notice they overlap as the new one is started, well they may see a slight delay in the next call but due to the design of the framework it will reconnect and not error. I have restarted the server  and not had to close the client which is pretty nice.
But just for clarification what support may have learned is not how it works. There were issues with data model regeneration not copying the data models over and requiring this to be done twice but I just didn’t want people thinking there are two different app pools when you recycle and your connected clients are linked to another – they are not…
If you are getting errors like logic not executing you need to review the event viewer and enable tracing. Sometimes if resources are low calls will not be returned due to low memory but you would always see this in the event viewer.
Sent: 12 February 2015 22:28
Thanks for the feedback Jose. I tried that before and it didn't work but I understand what you are saying
From talking to support, and, it should be added, they just learned something recently from developers in E10, if you add a UD field and then bind that to a database, and then regenerate a data model without everyone off the system (which I am guilty of) and then restart the app pool and IIS, those people who were logged in are actually part of a different app pool, so to them their services are not running because they still belong to the old app pool.
This kind of makes sense because there has to be something that triggers something to stop working. We are in implementation stage and there is development work going on so I am kind of leaning towards something like that as the root cause
On Thursday, February 12, 2015 2:09 PM, "Jose Gomez jose@... [vantage]" <vantage@yahoogroups.com> wrote:
There is a bug I ran into in 700.3 where the work around was to change your field matching from = to BEGINS with then set the Filter on Null Flag. GIve that a shot.
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
On Thu, Feb 12, 2015 at 1:46 PM, Mark Wagner mjfw2003@... [vantage] <vantage@yahoogroups.com> wrote:
We will go for a period of time with no issue and then when you try to use a quick search (user created or epicor) they return no results. Restarting the task agent sometimes works, other times not. Sometimes we have to recycle the app pool to get it to work
Anyone else seeing this? Epicor support has no calls on it. We are on E10.0.700.3
Stephen Edginton (Beng) | Solutions & Technical Director
Mobile:
 +44 7734 858415
DDI:
 +44 121 314 1179
Main:
 +44 (0) 121 314 1170
Web:
 www.dotnetit.co.uk
Dot Net IT Limited, One St Kenelm Court, Steel Park Road, Halesowen, B62 8HD, United Kingdom.
DotNetIT
Epicor Platinum Partner
Epicor Alliance Partner
Mobile:  +44 7734 858415
DDI:  +44 121 314 1179
Main:  +44 (0) 121 314 1170
Web:  www.dotnetit.co.uk
DotNetIT
Jose C Gomez
Software Engineer
Â
<div>
  <p></p><div style="color:#000;background-color:#fff;font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;"><div dir="ltr">We will go for a period of time with no issue and then when you try to use a quick search (user created or epicor) they return no results. Restarting the task agent sometimes works, other times not. Sometimes we have to recycle the app pool to get it to work</div><div dir="ltr"><br></div><div dir="ltr">Anyone else seeing this? Epicor support has no calls on it. We are on E10.0.700.3</div></div><p></p>
</div>
<div style="color:#fff;min-height:0;"></div>
<div id="ygrps-yiv-1888449780yiv3176319343ygrp-text">
  <div></div><div dir="ltr"><div class="ygrps-yiv-1888449780yiv3176319343gmail_default" style="font-family:verdana, sans-serif;font-size:small;">There is a bug I ran into in 700.3 where the work around was to change your field matching from = to BEGINS with then set the Filter on Null Flag. GIve that a shot.</div></div><div class="ygrps-yiv-1888449780yiv3176319343gmail_extra"><br clear="all"><div><div class="ygrps-yiv-1888449780yiv3176319343gmail_signature"><div dir="ltr"><div><font face="verdana, sans-serif"><br clear="none"><font color="#333333"><b>Jose C Gomez</b></font></font></div><div><font color="#666666" face="verdana, sans-serif" size="1"><b>Software Engineer<br clear="none"><br clear="none"></b></font></div><div><font face="verdana, sans-serif"><font><font color="#666666"><b><br clear="none"></b></font><font color="#FF6600" size="1">T: </font></font><font size="1"><span title="Call with Google Voice"><span title="Call with Google Voice">904.469.1524</span></span> mobile</font></font></div><div><font size="1" face="verdana, sans-serif"><font color="#FF6600">E:</font> <a rel="nofollow" shape="rect" target="_blank" href="mailto:jose@...">jose@...</a></font><font size="1" face="verdana, sans-serif"><br clear="none"><a rel="nofollow" shape="rect" target="_blank" href="http://www.josecgomez.com/"><font color="#FF6600">http://www.josecgomez.com</font></a><br clear="none"><a rel="nofollow" shape="rect" target="_blank" href="http://www.linkedin.com/in/josecgomez" style="font-size:small;"><img src="https://ec.yimg.com/ec?url=http%3A%2F%2Fwww.josecgomez.com%2Fimages%2Flinkedin.png&t=1472996563&sig=DhyG346hdjecW5ecmXhWCw--~C"></a>&nbsp;<a rel="nofollow" shape="rect" target="_blank" href="http://www.facebook.com/josegomez" style="font-size:small;"><img src="https://ec.yimg.com/ec?url=http%3A%2F%2Fwww.josecgomez.com%2Fimages%2Ffacebook.png&t=1472996563&sig=L4r5bylVo9Z3IaCHPfDJoQ--~C"></a>&nbsp;</font><a rel="nofollow" shape="rect" target="_blank" href="http://www.google.com/profiles/jose.gomez"><img src="https://ec.yimg.com/ec?url=http%3A%2F%2Fwww.josecgomez.com%2Fimages%2Fgoogle.png&t=1472996563&sig=Xy76qK0ifO.wFkr873p56w--~C"></a>&nbsp;<a rel="nofollow" shape="rect" target="_blank" href="http://www.twitter.com/joc85"><img src="https://ec.yimg.com/ec?url=http%3A%2F%2Fwww.josecgomez.com%2Fimages%2Ftwitter.png&t=1472996563&sig=xN4BAAM4MGE8wbrmIEYO_g--~C"></a>&nbsp;<a rel="nofollow" shape="rect" target="_blank" href="http://www.josecgomez.com/professional-resume/"><img src="https://ec.yimg.com/ec?url=http%3A%2F%2Fwww.josecgomez.com%2Fimages%2Fwp.png&t=1472996563&sig=frZwmv8w3dzIPM04o7h6eA--~C"></a>&nbsp;<span style="font-family:verdana, sans-serif;"><a rel="nofollow" shape="rect" target="_blank" href="http://www.josecgomez.com/feed/"><img src="https://ec.yimg.com/ec?url=http%3A%2F%2Fwww.josecgomez.com%2Fimages%2Frss.png&t=1472996563&sig=9NXuV3jjzsFpG_Toybm8iA--~C"></a>&nbsp;</span></div><div><span lang="LA" style="color:black;"><br clear="none"><font face="Verdana, sans-serif" style="font-weight:bold;" size="1"><i>Quis custodiet
ipsos custodes?
<div>
  <div></div><div style="color:#000;background-color:#fff;font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;"><div dir="ltr">We will go for a period of time with no issue and then when you try to use a quick search (user created or epicor) they return no results. Restarting the task agent sometimes works, other times not. Sometimes we have to recycle the app pool to get it to work</div><div dir="ltr"><br clear="none"></div><div dir="ltr">Anyone else seeing this? Epicor support has no calls on it. We are on E10.0.700.3</div></div><div></div>
</div>
</div>
<div class="ygrps-yiv-1888449780yiv3176319343yqt8184871468" id="ygrps-yiv-1888449780yiv3176319343yqt56625"><div style="color:#fff;height:0;"></div></div>
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343 -- #ygrps-yiv-1888449780yiv3176319343ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343ygrp-mkp #ygrps-yiv-1888449780yiv3176319343hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343ygrp-mkp #ygrps-yiv-1888449780yiv3176319343ads {
margin-bottom:10px;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343ygrp-mkp .ygrps-yiv-1888449780yiv3176319343ad {
padding:0 0;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343ygrp-mkp .ygrps-yiv-1888449780yiv3176319343ad p {
margin:0;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343ygrp-mkp .ygrps-yiv-1888449780yiv3176319343ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343ygrp-sponsor #ygrps-yiv-1888449780yiv3176319343ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343ygrp-sponsor #ygrps-yiv-1888449780yiv3176319343ygrp-lc #ygrps-yiv-1888449780yiv3176319343hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343ygrp-sponsor #ygrps-yiv-1888449780yiv3176319343ygrp-lc .ygrps-yiv-1888449780yiv3176319343ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343activity span {
font-weight:700;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343activity span span {
color:#ff7900;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343activity span .ygrps-yiv-1888449780yiv3176319343underline {
text-decoration:underline;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 .ygrps-yiv-1888449780yiv3176319343attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 .ygrps-yiv-1888449780yiv3176319343attach div a {
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 .ygrps-yiv-1888449780yiv3176319343attach img {
border:none;padding-right:5px;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 .ygrps-yiv-1888449780yiv3176319343attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 .ygrps-yiv-1888449780yiv3176319343attach label a {
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 .ygrps-yiv-1888449780yiv3176319343bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 .ygrps-yiv-1888449780yiv3176319343bold a {
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 dd.ygrps-yiv-1888449780yiv3176319343last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 dd.ygrps-yiv-1888449780yiv3176319343last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 dd.ygrps-yiv-1888449780yiv3176319343last p span.ygrps-yiv-1888449780yiv3176319343yshortcuts {
margin-right:0;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 div.ygrps-yiv-1888449780yiv3176319343attach-table div div a {
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 div.ygrps-yiv-1888449780yiv3176319343attach-table {
width:400px;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 div.ygrps-yiv-1888449780yiv3176319343file-title a, #ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 div.ygrps-yiv-1888449780yiv3176319343file-title a:active, #ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 div.ygrps-yiv-1888449780yiv3176319343file-title a:hover, #ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 div.ygrps-yiv-1888449780yiv3176319343file-title a:visited {
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 div.ygrps-yiv-1888449780yiv3176319343photo-title a, #ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 div.ygrps-yiv-1888449780yiv3176319343photo-title a:active, #ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 div.ygrps-yiv-1888449780yiv3176319343photo-title a:hover, #ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 div.ygrps-yiv-1888449780yiv3176319343photo-title a:visited {
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 div#ygrps-yiv-1888449780yiv3176319343ygrp-mlmsg #ygrps-yiv-1888449780yiv3176319343ygrp-msg p a span.ygrps-yiv-1888449780yiv3176319343yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 .ygrps-yiv-1888449780yiv3176319343green {
color:#628c2a;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 .ygrps-yiv-1888449780yiv3176319343MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 o {
font-size:0;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343photos div {
float:left;width:72px;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343reco-category {
font-size:77%;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343reco-desc {
font-size:77%;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 .ygrps-yiv-1888449780yiv3176319343replbq {
margin:4px;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343ygrp-mlmsg select, #ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 input, #ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343ygrp-mlmsg pre, #ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 code {
font:115% monospace;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343ygrp-mlmsg #ygrps-yiv-1888449780yiv3176319343logo {
padding-bottom:10px;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343ygrp-msg p#ygrps-yiv-1888449780yiv3176319343attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343ygrp-reco #ygrps-yiv-1888449780yiv3176319343reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343ygrp-sponsor #ygrps-yiv-1888449780yiv3176319343ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343ygrp-sponsor #ygrps-yiv-1888449780yiv3176319343ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343ygrp-sponsor #ygrps-yiv-1888449780yiv3176319343ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343ygrp-text {
font-family:Georgia;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1888449780 #ygrps-yiv-1888449780yiv3176319343 #ygrps-yiv-1888449780yiv3176319343ygrp-vital ul li:last-child {
border-right:none !important;}
#ygrps-yiv-1690040536 P.ygrps-yiv-1690040536b1e7fd89-0279-4ffe-a16a-1f1bcba0d537 { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-1690040536 LI.ygrps-yiv-1690040536b1e7fd89-0279-4ffe-a16a-1f1bcba0d537 { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-1690040536 DIV.ygrps-yiv-1690040536b1e7fd89-0279-4ffe-a16a-1f1bcba0d537 { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-1690040536 TABLE.ygrps-yiv-1690040536b1e7fd89-0279-4ffe-a16a-1f1bcba0d537Table { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-1690040536 DIV.ygrps-yiv-1690040536Section1 { }
Jose C Gomez
Software Engineer
DotNetIT
<div id="ygrps-yiv-1761984931yiv2901337098ygrp-text">
  <div>
Jose C Gomez
Software Engineer
DotNetIT
</div>
<div class="ygrps-yiv-1761984931yiv2901337098yqt4725369306" id="ygrps-yiv-1761984931yiv2901337098yqt37516"><div style="color:#fff;height:0;"></div></div>
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098 -- #ygrps-yiv-1761984931yiv2901337098ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098ygrp-mkp hr {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098ygrp-mkp #ygrps-yiv-1761984931yiv2901337098hd {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098ygrp-mkp #ygrps-yiv-1761984931yiv2901337098ads {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098ygrp-mkp .ygrps-yiv-1761984931yiv2901337098ad {
padding:0 0;}
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098ygrp-mkp .ygrps-yiv-1761984931yiv2901337098ad p {
margin:0;}
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098ygrp-mkp .ygrps-yiv-1761984931yiv2901337098ad a {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098ygrp-sponsor #ygrps-yiv-1761984931yiv2901337098ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098ygrp-sponsor #ygrps-yiv-1761984931yiv2901337098ygrp-lc #ygrps-yiv-1761984931yiv2901337098hd {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098ygrp-sponsor #ygrps-yiv-1761984931yiv2901337098ygrp-lc .ygrps-yiv-1761984931yiv2901337098ad {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098actions {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098activity {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098activity span {
font-weight:700;}
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098activity span:first-child {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098activity span a {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098activity span span {
color:#ff7900;}
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098activity span .ygrps-yiv-1761984931yiv2901337098underline {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 .ygrps-yiv-1761984931yiv2901337098attach {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 .ygrps-yiv-1761984931yiv2901337098attach div a {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 .ygrps-yiv-1761984931yiv2901337098attach img {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 .ygrps-yiv-1761984931yiv2901337098attach label {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 .ygrps-yiv-1761984931yiv2901337098attach label a {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 .ygrps-yiv-1761984931yiv2901337098bold {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 .ygrps-yiv-1761984931yiv2901337098bold a {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 dd.ygrps-yiv-1761984931yiv2901337098last p a {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 dd.ygrps-yiv-1761984931yiv2901337098last p span {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 dd.ygrps-yiv-1761984931yiv2901337098last p span.ygrps-yiv-1761984931yiv2901337098yshortcuts {
margin-right:0;}
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 div.ygrps-yiv-1761984931yiv2901337098attach-table div div a {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 div.ygrps-yiv-1761984931yiv2901337098attach-table {
width:400px;}
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 div.ygrps-yiv-1761984931yiv2901337098file-title a, #ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 div.ygrps-yiv-1761984931yiv2901337098file-title a:active, #ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 div.ygrps-yiv-1761984931yiv2901337098file-title a:hover, #ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 div.ygrps-yiv-1761984931yiv2901337098file-title a:visited {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 div.ygrps-yiv-1761984931yiv2901337098photo-title a, #ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 div.ygrps-yiv-1761984931yiv2901337098photo-title a:active, #ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 div.ygrps-yiv-1761984931yiv2901337098photo-title a:hover, #ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 div.ygrps-yiv-1761984931yiv2901337098photo-title a:visited {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 div#ygrps-yiv-1761984931yiv2901337098ygrp-mlmsg #ygrps-yiv-1761984931yiv2901337098ygrp-msg p a span.ygrps-yiv-1761984931yiv2901337098yshortcuts {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 .ygrps-yiv-1761984931yiv2901337098green {
color:#628c2a;}
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 .ygrps-yiv-1761984931yiv2901337098MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 o {
font-size:0;}
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098photos div {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098photos div div {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098photos div label {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098reco-category {
font-size:77%;}
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098reco-desc {
font-size:77%;}
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 .ygrps-yiv-1761984931yiv2901337098replbq {
margin:4px;}
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098ygrp-actbar div a:first-child {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098ygrp-mlmsg {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098ygrp-mlmsg table {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098ygrp-mlmsg select, #ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 input, #ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 textarea {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098ygrp-mlmsg pre, #ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 code {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098ygrp-mlmsg * {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098ygrp-mlmsg #ygrps-yiv-1761984931yiv2901337098logo {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098ygrp-msg p a {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098ygrp-msg p#ygrps-yiv-1761984931yiv2901337098attach-count span {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098ygrp-reco #ygrps-yiv-1761984931yiv2901337098reco-head {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098ygrp-reco {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098ygrp-sponsor #ygrps-yiv-1761984931yiv2901337098ov li a {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098ygrp-sponsor #ygrps-yiv-1761984931yiv2901337098ov li {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098ygrp-sponsor #ygrps-yiv-1761984931yiv2901337098ov ul {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098ygrp-text {
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1761984931 #ygrps-yiv-1761984931yiv2901337098 #ygrps-yiv-1761984931yiv2901337098ygrp-vital ul li:last-child {
