The BPM definitions are stored in the database. To “recompile” a BPM, just disable it, then re-enable it. That should force the server to recompile the BPM.
If that doesn’t work then do the following:
1. Open the BPM in the designer.
2. Make a change of some kind and then change it back.
3. Click “Save and Exit”.
4. Then click save on the toolbar.
5. Your BPM should be recompiled now.
The C:\inetpub\wwwroot\<AppServerName>\Server\BPM folders are only there to provide a space for compiling the assembly. They are very helpful when trying to fix compile errors since the line numbers will match up with the compiler error messages.
Bob Miller
Network/Systems Administrator
Al-Fe Corporate Group
Phone: 260-747-9422 x120
Direct: 260-739-1264
Mobile: 260-414-2393
Fax: 260-747-9618
