In Application Server Setup on Social Enterprise tab when I click New I have error Application Server Setup. “Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately”…“Input string was not in a correct format”.
On any other tabs like web access, enterprise search, Epicor education etc. all works perfect. I’m on 10.1.600.30 version. Any idea?
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.FormatException: Input string was not in a correct format.
at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
at System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info)
at System.Convert.ToInt32(String value)
at Ice.Tools.IIS7Administration.GetSiteUrls(String serverName, String siteName)
at SetupEnvironmentUI.DataSets.SetupEnvironmentDataSet.SUSocialEntRow.UpdateSiteURL()
at SetupEnvironmentUI.DataSets.SetupEnvironmentDataSet.SUSocialEntDataTable.SUSocialEntDataTable_ColumnChanged(Object sender, DataColumnChangeEventArgs e)
at System.Data.DataTable.OnColumnChanged(DataColumnChangeEventArgs e)
at System.Data.DataRow.set_Item(DataColumn column, Object value)
at SetupEnvironmentUI.SetupMaint.SUSocialEnt_TableNewRow(Object sender, DataTableNewRowEventArgs e)
at System.Data.DataTableNewRowEventHandler.Invoke(Object sender, DataTableNewRowEventArgs e)
at System.Data.DataTable.OnTableNewRow(DataTableNewRowEventArgs e)
at System.Data.DataTable.NewRowCreated(DataRow row)
at System.Data.DataView.AddNew()
at System.Windows.Forms.BindingSource.AddNew()
at SetupEnvironmentUI.Panels.SocialEnterprisePanel.AddRecord()
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.7.3190.0 built by: NET472REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
SetupEnvironmentUI
Assembly Version: 3.1.600.0
Win32 Version: 3.1.600.30
CodeBase: file:///C:/Program%20Files%20(x86)/Common%20Files/Epicor%20Software/Application%20Server%20Manager%20Extensions/3.1.600/SetUpEnvironment/SetupEnvironmentUI.exe
System
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
Win32 Version: 4.7.3062.0 built by: NET472REL1
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Data
Win32 Version: 4.7.3163.0 built by: NET472REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Data.DataSetExtensions
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Data.DataSetExtensions/v4.0_4.0.0.0__b77a5c561934e089/System.Data.DataSetExtensions.dll
System.Numerics
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
System.Configuration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
Ice.Tools.Common.CommandLineUtilities
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Common%20Files/Epicor%20Software/Application%20Server%20Manager%20Extensions/3.1.600/SetUpEnvironment/Ice.Tools.Common.CommandLineUtilities.DLL
Ice.Tools.InstallerBase
CodeBase: file:///C:/Program%20Files%20(x86)/Common%20Files/Epicor%20Software/Application%20Server%20Manager%20Extensions/3.1.600/SetUpEnvironment/Ice.Tools.InstallerBase.DLL
Microsoft.Web.Administration
Assembly Version: 7.0.0.0
Win32 Version: 8.5.9600.17042
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.Web.Administration/7.0.0.0__31bf3856ad364e35/Microsoft.Web.Administration.dll
System.Data.Entity
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Data.Entity/v4.0_4.0.0.0__b77a5c561934e089/System.Data.Entity.dll
Accessibility
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.ServiceProcess
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceProcess/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.ServiceProcess.dll
Epicor.Social.Deployment
Win32 Version: 3.1.600.0
CodeBase: file:///C:/Program%20Files%20(x86)/Common%20Files/Epicor%20Software/Application%20Server%20Manager%20Extensions/3.1.600/SetUpEnvironment/Epicor.Social.Deployment.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
