Personally, I find changing the timeout from 1800 to 900 to be a nice benefit, it trims the timeout down to 15 minutes instead of 30 minutes which is just a little too long in my mind.
Also, if for some reason you are actually using up to 60, then that could be telling you that you may have a record locking problem which will backup processes and cause more AppServers to spawn.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Nathan Anderson
Sent: Friday, July 08, 2011 6:58 PM
Subject: RE: [Vantage] E9.04.507A - App servers for on DB consuming 6GB of RAM
Hi Joe,
The starting point that I use for what the max number of servers should be for the main appserver is
((max number of users / 4) * 1.5) OR 20 whichever is higher, then adjust as needed from there
You are right, 60 seems like overkill, but if the demand isn’t there to spawn them then the number of servers will never reach that level. As long as your server has the resources to support 60 servers then it should be fine..
~Nathan
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Joe Rojas
Sent: Friday, July 08, 2011 5:19 PM
Hi Nathan,
It was:
Initial: 10
Min: 10
Max: 60
Now it is:
Initial: 5
Min: 5
Max: 60
Max of 60 sounds crazy for 32 user licenses but it was that way when I got here.
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On Behalf Of Nathan Anderson
Sent: Friday, July 08, 2011 5:28 PM
I apologize, I misread the issue – that darn ‘s’ at the end of appserver threw me off J
What do you have your min servers set to on your main appserver? If you can reduce the number of your min servers it will trim some of those appservers and release the memory if they aren’t being used.
~Nathan
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On Behalf Of Nathan Anderson
Sent: Friday, July 08, 2011 4:22 PM
To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
The memory leak issue fix is in 9.04.507a so something else is causing it.
With Epicor904 the appservers are 32bit so I don’t know how it would be possible for one 32bit application process to utilize more than 4GB of RAM
~Nathan
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On Behalf Of Doma Reddy
Sent: Friday, July 08, 2011 4:13 PM
To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
Subject: Re: [Vantage] E9.04.507A - App servers for on DB consuming 6GB of RAM
I think this is a known issue in the 9.04 Version, which is known as Memory leak issue.
This issue was resolved in 9.05
Hi Joe,
~Nathan
Hi Nathan,
It was:
Initial: 10
Min: 10
Max: 60
Now it is:
Initial: 5
Min: 5
Max: 60
~Nathan
~Nathan
--- On Fri, 7/1/11, Joe Rojas <jrojas@... <mailto:jrojas%40matsinc.com> <mailto:jrojas%40matsinc.com> <mailto:jrojas%40matsinc.com> <mailto:jrojas%40matsinc.com> > wrote:
From: Joe Rojas <jrojas@... <mailto:jrojas%40matsinc.com> <mailto:jrojas%40matsinc.com> <mailto:jrojas%40matsinc.com> <mailto:jrojas%40matsinc.com> >
Subject: [Vantage] E9.04.507A - App servers for on DB consuming 6GB of RAM
To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
Date: Friday, July 1, 2011, 2:10 PM
Hello,
Possibly related to my other email about slow order entry, I just finished running another data conversion to take 1,300 sales order off of credit hold.
It was a slow process but when it finally completed, I noticed that task manager was showing 9.8 GB of RAM used (12GB is installed).
I thought this was extreme because I only have the Pilot database running.
I stopped the app servers for Pilot and the RAM usage dropped over 6GB, down to 3.3GB.
My database is only 355MB (still implementing).
Anyone else encounter this issue? 6GB for a 355MB database seems really out of line. To the point where something must be wrong.
Joe Rojas | Director of Information Technology | Mats Inc
dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191 jrojas@... <mailto:jrojas%40matsinc.com> <mailto:jrojas%40matsinc.com> <mailto:jrojas%40matsinc.com> <mailto:jrojas%40matsinc.com> | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
Click here <https://www.mailcontrol.com/sr/wQw0zmjPoHdJTZGyOCrrhg==>>> to report this email as spam.
This e-mail is for the use of the intended recipient(s) only. If you have received this e-mail in error, please notify the sender immediately and then delete it. If you are not the intended recipient, you must not use, disclose or distribute this e-mail without the author's prior permission. We have taken precautions to minimize the risk of transmitting software viruses, but we advise you to carry out your own virus checks on any attachment to this message. We cannot accept liability for any loss or damage caused by software viruses. Any views and/or opinions expressed in this e-mail are of the author only and do not represent the views of Epicor Software Corporation or any other company within its group.
This message has been scanned for malware by Websense. www.websense.com
< <https://www.mailcontrol.com/sr/wQw0zmjPoHdJTZGyOCrrhg==> https://www.mailcontrol.com/sr/wQw0zmjPoHdJTZGyOCrrhg==>>
dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191 <https://www.mailcontrol.com/sr/wQw0zmjPoHdJTZGyOCrrhg==> jrojas@... <mailto:jrojas%40matsinc.com> | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
