Found out there is a fix for this. Contact support if you encounter the bug.
--- In vantage@yahoogroups.com, "Hyndman" <hyndmaninc@...> wrote:
> Has anyone encountered missing DimCodes on PartBin as a result of a material backflush transaction? This is happening sporadically. We backflush to a specific warehouse/bin, creating negative qty, then qty adjust the appropriate bins and zero the backflush bin. When the DimCode is missing we have to manually correct using SQL then run Conversion 6430.
