E9.05.700 Configurator Question - Add Material to Part Master
Deb Bland has an example of how to call Business Objects from ABL. You could use her example for the Part business object.
Mark W.
/* Copy Misc Chrgs for Quote at Header level to SO */
Â
/* Quote Misc Chrgs stored in UD07. Call SO business methods to add miscellaneous charges */
Â
DEF VAR iOrdNum as INTEGER no-undo.
DEF VAR iOrdLine as INTEGER no-undo INIT 0.
Â
DEF VAR DEBUGGING AS LOGICAL no-undo.
DEBUGGING = true.
Â
IF DEBUGGING THEN DO:
           output to value("d:\RestekERP\Logs\BPM\SalesOrder_CreateOrderFromQuote_QuoteMiscChrgs.txt").
           export string(Now) + " in Quote Misc Chrgs of SalesOrder.CreateOrderFromQuote".
END.
Â
FIND FIRST ttOrderHed WHERE ttOrderHed.Company = Cur-Comp no-lock no-error.
IF AVAIL ttOrderHed THEN DO:
                       iOrdNum = ttOrderHed.OrderNum.
Â
                       IF DEBUGGING THEN export "Order num=" + string(iOrdNum) + " QuoteNum=" + string(iQuoteNum).
          Â
                       FOR EACH UD07 no-lock WHERE UD07.Company = Cur-Comp AND Key2=string(iQuoteNum):
Â
                                                run GetNewOHOrderMsc({&input-output_dataset_SalesOrderDataSet}, input iOrdNum, input iOrdLine) no-error.
                                               IF DEBUGGING THEN export string(Now) + " in GetNewOHOrderMsc".
Â
                                               FIND FIRST ttOHOrderMsc WHERE ttOHOrderMsc.Company=Cur-Comp AND ttOHOrderMsc.RowMod = 'A' no-lock no-error.
                                               IF AVAIL ttOHOrderMsc THEN DO:
        IF DEBUGGING THEN export string(Now) + " OrderMsc rec found. UD07.Key3=" + UD07.Key3.
        ttOHOrderMsc.MiscCode = UD07.Key3.
                                               END.
                                               ELSE DO:
        If DEBUGGING THEN export string(Now) + " No OrderMsc rec found".
                                               END.
Â
                                                run ChangeMiscCode({&input-output_dataset_SalesOrderDataSet}, input "OHOrderMsc").
                                               IF DEBUGGING THEN export string(Now) + " in ChangeMiscCode".
Â
                                               /* Frequently, when using BO methods inside of BPM, you need to go and get the record again after calling a method. */
        IF DEBUGGING THEN export string(Now) + " OrderMsc rec found. UD07.Shortchar02=" + UD07.Shortchar02 + " Number01=" + string(UD07.Number01) + " Number02=" + string(UD07.Number02).
Â
        /* User can change charge amount/percentage in the quote. Grab the amount/percentage from UD07. */
        IF UD07.Number01 <> 0 THEN DO:
        ttOHOrderMsc.DocDspMiscAmt = UD07.Number01.
        run ChangeMiscAmount({&input-output_dataset_SalesOrderDataSet}, input "OHOrderMsc").
        END.
        ELSE DO:
        IF UD07.Number02 <> 0 THEN DO:
        ttOHOrderMsc.Percentage = UD07.Number02.
        run ChangeMiscPercent({&input-output_dataset_SalesOrderDataSet}, input "OHOrderMsc").
        END.
        END.
                                               END.
Â
        ttOHOrderMsc.FreqCode = UD07.ShortChar02.
                                               END.
Â
                                                run Update({&input-output_dataset_SalesOrderDataSet}) no-error.
                                               IF DEBUGGING THEN export string(Now) + " in Update".
                       END.
END.
On Wed, Dec 11, 2013 at 9:50 AM, Mark Wagner <mjfw2003@...> wrote:
Â
<div>
  <p></p><div style="font-size:12pt;font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;"><div>We have a purchased material on a configured parts BOM as a placeholder for a part that can be many different colors. When the part is configured we create a job material part number on the fly and it defaults as purchase direct, but we would like to have the part actually create a part master and then allow the material to appear in purchase suggestions as purchase to stock.</div>
Anyone out there creating a part master at the time of the configuration and then adding it to the job BOM as a purchase to stock part?
</div>
<div style="color:#fff;min-height:0;"></div>
