E9.05 - SalesOrder.Update vs SalesOrder.MasterUpdate
Thanks Jose
This worked and now i dont get the refresh issue anymore
On Tue, Jan 15, 2013 at 1:25 PM, Jose Gomez <jose@...> wrote:
> within ABL
> *Jose C Gomez*
> *Software Engineer*
> *T: 904.469.1524 mobile
> E: jose@...
> http://www.josecgomez.com
> <http://www.linkedin.com/in/josecgomez> <
> http://www.facebook.com/josegomez>
> <http://www.google.com/profiles/jose.gomez> <
> http://www.twitter.com/joc85>
> <http://www.josecgomez.com/professional-resume/>
> <http://www.josecgomez.com/feed/>
> <http://www.usdoingstuff.com>
> *Quis custodiet ipsos custodes?*
> On Tue, Jan 15, 2013 at 1:23 PM, Ephraim Feldman <effgroups@...
> >wrote:
> > So this i put in the ABL call
> > Or do i have to call a outside procedure?
> > On Tue, Jan 15, 2013 at 1:21 PM, Jose Gomez jose@...> wrote:
> > > Here is a call to get By ID on a different module but its very similar
> > just
> > > use the rigth parameters (which you can get from the GetByID method in
> > BPM)
> > > pcGroupIO abd ipHeadNum are variabgles I declared and set.
> > > DEFINE VARIABLE hCashReceipt AS HANDLE NO-UNDO.
> > > RUN BO/CashRec/CashRec.p PERSISTENT SET hCashReceipt.
> > > RUN GetByID IN hCashReceipt(INPUT pcGroupID, INPUT ipHeadNum, OUTPUT
> > > DataSet CashRecDataSet).
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@...
> > > On Tue, Jan 15, 2013 at 12:48 PM, Ephraim Feldman effgroups@...
> > > >wrote:
> > > > Can you please guide me how to do it in the BPM?
> > > > On Tue, Jan 15, 2013 at 12:33 PM, Jose Gomez jose@...>
> > wrote:
> > > > > After your Update in your BPM just run a GetByID to refresh the
> > dataset
> > > > > (whithin the BPM)
> > > > > *Jose C Gomez*
> > > > > *Software Engineer*
> > > > > E: jose@...
> > > > > On Tue, Jan 15, 2013 at 12:27 PM, Ephraim Feldman
> > effgroups@...
> > > > > >wrote:
> > > > > > Somehow it seems to me that the MasterUpdate is causing issues
> for
> > me
> > > > > > We have a few BPM's on the update method and some of them are on
> > the
> > > > Post
> > > > > > Process
> > > > > > Till now in version 9.04 i handled the refresh issue with doing a
> > > > > > otrans.refresh in the AfterAdapterMethod of the Update but now
> this
> > > is
> > > > > > causing the refresh to run before the full update is processed
> > > > > > As a example when i change the need by date or the request date
> > then
> > > it
> > > > > > will refresh and reset the dates back before popping up the box
> if
> > i
> > > > want
> > > > > > to change all the lines.
> > > > > > Also when changing a price on a line of a order with many lines
> it
> > > will
> > > > > > take much longer to update and a trace showed it runs the master
> > > update
> > > > > > My assumption is that it runs multiple times the Update with all
> > the
> > > > > BPM's
> > > > > > so it takes longer
> > > > > > can anyone help me with this
> > > > > > On Fri, Oct 12, 2012 at 4:28 PM, Jose Gomez jose@...>
> > > > wrote:
> > > > > > > Yes and Yes (in theory :))
> > > > > > > *Jose C Gomez*
> > > > > > > *Software Engineer*
> > > > > > > E: jose@...
> > > > > > > On Fri, Oct 12, 2012 at 3:57 PM, Joe Rojas jrojas@...>
> > > > wrote:
> > > > > > > > Thanks Jose.
> > > > > > > > So if I was using this method in a customization, would I
> just
> > > > update
> > > > > > > > all required rows, mark each as RowMod = "U" and then submit
> > the
> > > > > > dataset
> > > > > > > > to MasterUpdate?
> > > > > > > > Can I update multiple lines in each table in the dataset?
> > Meaning
> > > > > > > > OrderHed AND OrderDtl AND OrderRel at the same time?
> > > > > > > > Joe Rojas | Director of Information Technology | Mats Inc
> > > > > > > > dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
> > > > > > > > jrojas@... | www.matsinc.com Ask us about our clean,
> > > green
> > > > > and
> > > > > > > > beautiful matting and flooring
> > > > > > > > This message is intended only for the individual named. If
> you
> > > are
> > > > > not
> > > > > > > the
> > > > > > > > named addressee you should not disseminate, distribute or
> copy
> > > this
> > > > > > > e-mail.
> > > > > > > > Please notify the sender immediately by e-mail if you have
> > > received
> > > > > > this
> > > > > > > > e-mail by mistake. Please note that any views or opinions
> > > presented
> > > > > in
> > > > > > > this
> > > > > > > > email are solely those of the author and do not necessarily
> > > > represent
> > > > > > > those
> > > > > > > > of the company.
> > > > > > > > -----Original Message-----
> > > > > > > > From: vantage@yahoogroups.com [mailto:
> vantage@yahoogroups.com]
> > > On
> > > > > > Behalf
> > > > > > > > Of Jose Gomez
> > > > > > > > Sent: Friday, October 12, 2012 3:31 PM
> > > > > > > > To: vantage@yahoogroups.com
> > > > > > > > Subject: Re: [Vantage] E9.05 - SalesOrder.Update vs
> > > > > > > > Master allows to update multiple records at once. It uses the
> > > > update
> > > > > > > > method internally.
> > > > > > > > It was made to speed up SO Entry. Now instead of updating
> each
> > > line
> > > > > you
> > > > > > > > can ran a Master Update and Update Multiple Lines at once.
> > > > > > > > *Jose C Gomez*
> > > > > > > > *Software Engineer*
> > > > > > > > E: jose@...
> > > > > > > > On Fri, Oct 12, 2012 at 3:21 PM, Joe Rojas
> jrojas@...>
> > > > > wrote:
> > > > > > > > > Hi All,
> > > > > > > > > Can someone speak to what the differences are between the
> > > methods
> > > > > > > > > Update and MasterUpdate on the SalesOrder BO?
> > > > > > > > > We are working to convert from 9.04.507A to 9.05.700x and
> > while
> > > > > doing
> > > > > > > > > a trace in 9.05, I noticed that MasterUpdate in now called
> > > > instead
> > > > > of
> > > > > > > > > Update.
> > > > > > > > > What I found interesting though is that we have over 25
> > method
> > > > > > > > > directives on Update and they are still triggered.
> clean,
> > > > green
> > > > > > and
> > you
> > > > are
> > > > > > not
> > > > > > > > > the named addressee you should not disseminate, distribute
> or
> > > > copy
> > > > > > > > this e-mail.
> > > > received
> > > > > > > > > this e-mail by mistake. Please note that any views or
> > opinions
> > > > > > > > > presented in this email are solely those of the author and
> do
> > > not
> > > > > > > > > necessarily represent those of the company.
> > > > > > > > > [Non-text portions of this message have been removed]
> > > > > > > > Useful links for the Yahoo!Groups Vantage Board are: ( Note:
> > You
> > > > must
> > > > > > > > have already linked your email address to a yahoo id to
> enable
> > > > > access.
> > > > > > > > (1) To access the Files Section of our Yahoo!Group for Report
> > > > Builder
> > > > > > > > and Crystal Reports and other 'goodies', please goto:
> > > > > > > > http://groups.yahoo.com/group/vantage/files/.
> > > > > > > > (2) To search through old msg's goto:
> > > > > > > > http://groups.yahoo.com/group/vantage/messages
> > > > > > > > (3) To view links to Vendors that provide Vantage services
> > goto:
> > > > > > > > http://groups.yahoo.com/group/vantage/linksYahoo! Groups
> Links
> You
> > > must
> > > > > > > have already linked your email address to a yahoo id to enable
> > > > access.
> > > Builder
> > > > > and
> goto:
> > > > > > > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> > > > > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
> must
> > access.
> Builder
> > > and
> > > > > (3) To view links to Vendors that provide Vantage services goto:
> > > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > > have already linked your email address to a yahoo id to enable access.
> > > (1) To access the Files Section of our Yahoo!Group for Report Builder
> and
> have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
Hi All,
Can someone speak to what the differences are between the methods Update
We are working to convert from 9.04.507A to 9.05.700x and while doing a
trace in 9.05, I noticed that MasterUpdate in now called instead of
Update.
What I found interesting though is that we have over 25 method
jrojas@... | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
Master allows to update multiple records at once. It uses the update method
internally.
It was made to speed up SO Entry. Now instead of updating each line you can
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Fri, Oct 12, 2012 at 3:21 PM, Joe Rojas <jrojas@...> wrote:
> Hi All,
> Update.
> of the company.
Thanks Jose.
So if I was using this method in a customization, would I just update
all required rows, mark each as RowMod = "U" and then submit the dataset
to MasterUpdate?
Can I update multiple lines in each table in the dataset? Meaning
Of Jose Gomez
method internally.
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Hi All,
> a trace in 9.05, I noticed that MasterUpdate in now called instead of
> Update.
this e-mail.
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Fri, Oct 12, 2012 at 3:57 PM, Joe Rojas <jrojas@...> wrote:
> Thanks Jose.
> to MasterUpdate?
> of the company.
> Of Jose Gomez
> method internally.
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Hi All,
> > Update.
> this e-mail.
Somehow it seems to me that the MasterUpdate is causing issues for me
We have a few BPM's on the update method and some of them are on the Post
Process
otrans.refresh in the AfterAdapterMethod of the Update but now this is
As a example when i change the need by date or the request date then it
will refresh and reset the dates back before popping up the box if i want
Also when changing a price on a line of a order with many lines it will
take much longer to update and a trace showed it runs the master update
My assumption is that it runs multiple times the Update with all the BPM's
so it takes longer
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Thanks Jose.
> > to MasterUpdate?
> the
> e-mail.
> this
> those
> > of the company.
> > Of Jose Gomez
> > method internally.
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > > Hi All,
> > > Update.
> > this e-mail.
After your Update in your BPM just run a GetByID to refresh the dataset
(whithin the BPM)
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Process
> so it takes longer
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > On Fri, Oct 12, 2012 at 3:57 PM, Joe Rojas jrojas@...> wrote:
> > > Thanks Jose.
> dataset
> > > to MasterUpdate?
> > the
> > e-mail.
> this
> > this
> > those
> > > of the company.
> Behalf
> > > Of Jose Gomez
> > > method internally.
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@...
> > > On Fri, Oct 12, 2012 at 3:21 PM, Joe Rojas jrojas@...> wrote:
> > > > Hi All,
> > > > Update.
> and
> not
> > > this e-mail.
> (whithin the BPM)
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Process
> BPM's
> > so it takes longer
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@...
> > > > Thanks Jose.
> > dataset
> > > > to MasterUpdate?
> and
> not
> > > the
> > > e-mail.
> > this
> in
> > > this
> > > those
> > > > of the company.
> > Behalf
> > > > Of Jose Gomez
> > > > method internally.
> you
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@...
> wrote:
> > > > > Hi All,
> doing
> of
> > > > > Update.
> > and
> > not
> > > > this e-mail.
> access.
> and
Here is a call to get By ID on a different module but its very similar just
use the rigth parameters (which you can get from the GetByID method in BPM)
*Jose C Gomez*
*Software Engineer*
E: jose@...
> > (whithin the BPM)
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > On Tue, Jan 15, 2013 at 12:27 PM, Ephraim Feldman effgroups@...
> Post
> > > Process
> want
> > BPM's
> > > so it takes longer
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@...
> wrote:
> > > > > Thanks Jose.
> update
> > > dataset
> > > > > to MasterUpdate?
> > and
> > not
> > > > the
> > > > e-mail.
> > > this
> > in
> > > > this
> represent
> > > > those
> > > > > of the company.
> > > Behalf
> > > > > Of Jose Gomez
> update
> > > > > method internally.
> > you
> > > > > *Jose C Gomez*
> > > > > *Software Engineer*
> > > > > E: jose@...
> > wrote:
> > > > > > Hi All,
> > doing
> instead
> > of
> > > > > > Update.
> green
> > > and
> are
> > > not
> copy
> > > > > this e-mail.
> received
> must
> > access.
> Builder
> access.
> > and
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > > (whithin the BPM)
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@...
> > Post
> > > > Process
> is
> it
> > want
> will
> update
> > > BPM's
> > > > so it takes longer
> > > > > *Jose C Gomez*
> > > > > *Software Engineer*
> > > > > E: jose@...
> > wrote:
> > > > > > Thanks Jose.
> > update
> > > > dataset
> > > > > > to MasterUpdate?
> green
> > > and
> are
> > > not
> > > > > the
> this
> > > > > e-mail.
> received
> > > > this
> presented
> > > in
> > > > > this
> > represent
> > > > > those
> > > > > > of the company.
> On
> > > > Behalf
> > > > > > Of Jose Gomez
> > update
> > > > > > method internally.
> line
> > > you
> > > > > > *Jose C Gomez*
> > > > > > *Software Engineer*
> > > > > > E: jose@...
> > > wrote:
> > > > > > > Hi All,
> methods
> > > doing
> > instead
> > > of
> > > > > > > Update.
> > green
> > > > and
> > are
> > > > not
> > copy
> > > > > > this e-mail.
> > received
> not
> > must
> > > access.
> > Builder
> must
> > access.
> Builder
> > > and
> and
within ABL
*Jose C Gomez*
*Software Engineer*
E: jose@...
> just
> BPM)
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> dataset
> > > > (whithin the BPM)
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@...
> effgroups@...
> me
> the
> > > Post
> > > > > Process
> > is
> then
> > it
> i
> > > want
> > will
> > update
> the
> > > > BPM's
> > > > > so it takes longer
> > > > > > *Jose C Gomez*
> > > > > > *Software Engineer*
> > > > > > E: jose@...
> > > wrote:
> > > > > > > Thanks Jose.
> > > update
> the
> > > > > dataset
> > > > > > > to MasterUpdate?
> Meaning
> > green
> > > > and
> > are
> > > > not
> > > > > > the
> > this
> > > > > > e-mail.
> > received
> > > > > this
> > presented
> > > > in
> > > > > > this
> > > represent
> > > > > > those
> > > > > > > of the company.
> > On
> > > > > Behalf
> > > > > > > Of Jose Gomez
> > > update
> > > > > > > method internally.
> > line
> > > > you
> > > > > > > *Jose C Gomez*
> > > > > > > *Software Engineer*
> > > > > > > E: jose@...
> > > > wrote:
> > > > > > > > Hi All,
> > methods
> while
> > > > doing
> > > instead
> > > > of
> > > > > > > > Update.
> method
> > > green
> > > > > and
> you
> > > are
> > > > > not
> > > copy
> > > > > > > this e-mail.
> > > received
> opinions
> > not
> You
> > > must
> > > > access.
> > > Builder
> goto:
> > must
> > > access.
> > Builder
> > > > and
> access.
> > and
