E9.0x Multiple PO's on Packslip
We are on 8.03.409c - but we do not put a PO on the header - can you try that to see if it works?
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of chris_robisch
Sent: Wednesday, August 03, 2011 5:23 PM
Subject: [Vantage] E9.0x Multiple PO's on Packslip
Both 9.04 and 9.05 allow you to enter multiple PO's on one Packslip, as you might get from your supplier. The 2nd PO has to be entered on the Line, not the Header. But this presents a problem at Invoice time because it'll flag the Packslip as Invoiced on the first PO, thus not allowing you to process the 2nd PO. Workaround is to use a different Packslip for each PO but we believe the Invoicing should work, and if not, prevent the 2nd PO on the Receipt.
Anyone else encounter this? SCR? Enhancement Request? Thanks.
