E9 507A Patch and Fulfillment Workbench
Did you find that it also doesn't work on your end too?
We deal with flooring material that sometimes has a dye lot, which we
store as the batch number for lot tracked parts. The dye lot represents
the batch of the dye used to color the material. Because dye lot
coloring can be slightly off from lot to lot it is important for us to
be able to select lots that have the same dye lot number so that all of
the colors match exactly. In order to handle this, we need to allocate
material one sales order release at a time. As you can imagine, this
would be an extremely time consuming task. To address that, we had a
customization made that adds an Allocation tab to the Sales Order
Release tab, this tab shows all lots on hand and all we have to do is
tick a checkbox for the lot of material that we want and the
customization does the hard allocation for us.
We have the same thing on the Job Entry screen under Job Materials.
Because our parts are lot tracked, we do not backflush.
Of liss_c
Sent: Tuesday, January 11, 2011 4:44 PM
Subject: [Vantage] Re: E9 507A Patch and Fulfillment Workbench
I see. I just tested Allocation by Lot/Bin. But why taking the time to
allocate each individual line if when you can allocate by Part and all
records at once? That way you can let the software create hard
allocations for all the lines of the sales order.
In the job fulfillment... I know it wont work if you use backflush... DO
you use backflush?
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , Joe
Rojas <jrojas@...> wrote:
> In short...the Allocate by Lot/Bin just doesn't work.
> For example, we try to allocate material to a Sale Order release by
> doing an Allocate by Lot/Bin and everything seems to go fine, no
errors,
> but there is no allocation record made.
> If I do the process again it's like it never took place.
> Also, if a try to allocate material to a Job Material, it tells me
that
> I need to select a demand record even though the job material is
clearly
> selected.
> Tech support said that they identified this as a bug around 1/3. I'm
> anxiously waiting for a response because we allocate EVERY sales order
> and job material.
> Like I said...this is bad for us...really bad...
Behalf
> Of liss_c
> Sent: Tuesday, January 11, 2011 4:02 PM
> Subject: [Vantage] Re: E9 507A patch and Fulfillment Workbench
> Broken how? I am currently testing 507A because supposedly a lot of
our
> isues regarding the Fulfillment WB will be resolved in 507A. I havent
> foun anything unusual. Do you have any specific examples?
> Rojas <jrojas@> wrote:
> > Has anyone taken the plunge into the 507 and 507A patch that uses
the
> > Fulfillment Workbench?
> > It seems to be broken...
> > This is bad for us...really bad...
> > Joe Rojas | Director of Information Technology | Mats Inc
> > dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
> > jrojas@ | www.matsinc.com Ask us about our clean, green and
> beautiful matting and flooring
> > This message is intended only for the individual named. If you are
not
> the named addressee you should not disseminate, distribute or copy
this
> e-mail. Please notify the sender immediately by e-mail if you have
> received this e-mail by mistake. Please note that any views or
opinions
> presented in this email are solely those of the author and do not
> necessarily represent those of the company.
> jrojas@... | www.matsinc.com Ask us about our clean, green and
> This message is intended only for the individual named. If you are not
the named addressee you should not disseminate, distribute or copy this
received this e-mail by mistake. Please note that any views or opinions
jrojas@... | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
Has anyone taken the plunge into the 507 and 507A patch that uses the
Broken how? I am currently testing 507A because supposedly a lot of our isues regarding the Fulfillment WB will be resolved in 507A. I havent foun anything unusual. Do you have any specific examples?
doing an Allocate by Lot/Bin and everything seems to go fine, no errors,
Also, if a try to allocate material to a Job Material, it tells me that
I need to select a demand record even though the job material is clearly
selected.
and job material.
Of liss_c
I see. I just tested Allocation by Lot/Bin. But why taking the time to allocate each individual line if when you can allocate by Part and all records at once? That way you can let the software create hard allocations for all the lines of the sales order.
In the job fulfillment... I know it wont work if you use backflush... DO you use backflush?
> selected.
> and job material.
> Of liss_c
