[E9] C# Event Handling Code
I'd wager it can be done the easy way, any chance you can find out the "reasons"? Also what version are you on?Â
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
On Thu, Oct 2, 2014 at 5:07 PM, tooheymomster@... [vantage] <vantage@yahoogroups.com> wrote:
Â
<div>
  <p>Thanks Jose,</p><div>That&#39;s what I have been reading all day on Google. From what I was told, we can&#39;t do it the easy way because of it messing up with other things in our system and something about server side, which again, messes with our system...</div><div><br></div><div>I just don&#39;t know what it wants from me. I found everything it needs and converted the code and after all that, I am lost.</div><p></p>
</div><span class="ygrps-yiv-1307979074">
<div style="color:#fff;min-height:0;"></div>
Hi,
I have been working on a project with one of the tasks being to make the Reason Drop Down Box a REQUIRED field WHEN the Hold Flag is turned on in the Sales Order Entry screen.
So far, this is what I have done regarding this project:
SALES MANAGEMENT
> CUSTOMER RELATION MANAGEMENT > GENERAL OPERATIONS > ORDER ENTRY
Made a copy of SalesOrderEntry_CT_005
Renamed the copy to SalesOrderEntry_CT_006
Header > Detail tab
Added EpiLabel named lblHoldReason (Hold Reason:)
Added EpiUltraCombo named cboHoldReasons
Added the reasons in the drop down box:
Kanban/Blanket Order
Price Roll Up Due
Customer Hold
Unconfirmed Delivery
Documentation Review PRIOR to Shipment
Set EpiLabel : lblHoldReason
Set EpiBinding : ShortChar01 to OrderHed
Went into Method Directives and found SalesOrder.Update
Pre-Processing > BlanketToHold
Enabled was checked
Unchecked Enabled box
Saved Method Directives form
Instead of taking Blanket Checkbox and Blanket Button out:
Made Visible False for both
and
Enabled False for both
Added Form Event Wizard:
Event Type: BeforeAdapterMethod
Adapter: OrderAdapter
Traced to find out what METHOD NAME is being used
Method Name : MasterUpdate
Went into CUSTOM OBJECT EXPLORER to find the
Converted vb.net code to c#
Now for the part that I am not sure about:
In the Form Event Wizard, I need to edit the View/Edit Event Handling Code
private void oTrans_ordAdapter_BeforeAdapterMethod(object sender, BeforeAdapterMethodArgs args)
// ** args.MasterUpdate **
// ** Add Event Handler Code **
// ** Use MessageBox to find adapter method name
// EpiMessageBox.Show(args.MethodName)
switch (args.MethodName)
case "Update":
// DialogResult dialogResult = EpiMessageBox.Show("Cancel Update?", "Cancel", MessageBoxButtons.YesNo);
// if ((dialogResult == DialogResult.Yes))
// args.Cancel = true;
// } else
// DoSomethingElse();
break;
Through the Object Explorer I was able to find the code for the OrderHeld Checkbox and the ShortChar01 Reason Drop Down Box
OrderHed.ShortChar01
Dim [edvVarName] As EpiDataView = CType(oTrans.EpiDataViews("OrderHed"), EpiDataView)
Dim [VarName] As String = [edvVarName].dataView([edvVarName].Row)("ShortChar01")
'// ** Or
'// Dim [dvVarName] As DataView = [edvVarName].dataView
'// Dim [VarName] As String = [dvVarName]([edvVarName].Row)("ShortChar01")
CONVERTED FROM VB.NET TO C#
EpiDataView edvVarName = (EpiDataView)oTrans.EpiDataViews("OrderHed");
string VarName = edvVarName.dataView(edvVarName.Row)("ShortChar01");
//// ** Or
//// Dim [dvVarName] As DataView = [edvVarName].dataView
//// Dim [VarName] As String = [dvVarName]([edvVarName].Row)("ShortChar01")
OrderHed.OrderHeld
Dim [VarName] As Boolean = [edvVarName].dataView([edvVarName].Row)("OrderHeld")
'// ** Or
'// Dim [VarName] As Boolean = [dvVarName]([edvVarName].Row)("OrderHeld")
bool VarName = edvVarName.dataView(edvVarName.Row)("OrderHeld");
//// ** Or
//// Dim [VarName] As Boolean = [dvVarName]([edvVarName].Row)("OrderHeld")
And now....I am lost. Could someone give me a little direction?
I don't know what Epicor is looking for or what/where I should be putting the code.
Thank you!!!
Making fields required is a lot easier to do via a BPM, simply put a pre-processing BPM on Update / Master Update which checks if the Flag is Set and Raises an Exception if your field is Empty saves you all the heart ache and it works across the board.
Jose C Gomez
Software Engineer
On Thu, Oct 2, 2014 at 4:53 PM, tooheymomster@... [vantage] <vantage@yahoogroups.com> wrote:
Â
<div>
  <p></p><p>Hi,</p><p>I have been working on a project with one of the tasks being to make the Reason Drop Down Box a REQUIRED field WHEN the Hold Flag is turned on in the Sales Order Entry screen.</p><p><br></p><p>So far, this is what I have done regarding this project:</p><p style="margin:0in;font-family:Calibri;font-size:11.0pt;">SALES MANAGEMENT
Â
Made a copy of
Â
Renamed the copy to
Â
Header > Detail
tab
Â
Â
Added EpiUltraCombo
Â
the drop down box:
Price Roll Up Due
Customer Hold
PRIOR to Shipment
Â
Set EpiLabel :
lblHoldReason
Set EpiBinding :
Â
Went into Method
Pre-Processing >
BlanketToHold
Enabled was checked
Unchecked Enabled
box
Saved Method
Directives form
Â
Instead of taking
Made Visible False
for both
and
Enabled False for
both
Â
Added Form Event
Wizard:
Event Type:
BeforeAdapterMethod
Adapter:
OrderAdapter
Â
Traced to find out
Method Name :
MasterUpdate
Â
Went into CUSTOM
Â
case "Update":
// } else
break;
Â
'// ** Or
Â
//// ** Or
Â
Â
OrderHed.OrderHeld
Â
'// ** Or
Â
//// ** Or
Thank you!!!
</div>
Thanks Jose,
That's what I have been reading all day on Google. From what I was told, we can't do it the easy way because of it messing up with other things in our system and something about server side, which again, messes with our system...
I just don't know what it wants from me. I found everything it needs and converted the code and after all that, I am lost.
