[E9] Can anyone shed a little light on this error message?
So one or the other has to be checked or both? Not sure what the rules are with Inspection Required/Approved Supplier.
Thanks in advance!
Exception caught in: Epicor.Mfg.BO.POSugg
Error Detail
Message: Part (123456-001) is set to Inspection Required, but this is not an Approved Supplier.  Make this an Approved Supplier for the part before adding to PO.
Type: Error
Program: bo/POSugg/POSugg.p
Method: GeneratePre56_A1
Table:
Row:
Field:
Stack Trace
   at Epicor.Mfg.Proxy.POSuggImpl.Generate(POSuggDataSet ds, String ipPlantKey, String ipCurBuyer, Nullable`1 ipCutOffDate)
   at Epicor.Mfg.UI.Adapters.POSuggAdapter.Generate(String ipPlantKey, String ipCurBuyer, Nullable`1 ipCutOffDate)
Inner Exception
ERROR condition: The Server application has returned an error. (7243)  (7211)
Inner Stack Trace
   at Progress.Open4GL.DynamicAPI.Session.runProcedure(String requestID, String procedureName, ParameterSet parms, Boolean persistent, Boolean internal_Renamed, Int64 procId, MetaSchema localSchema, Int32 stateModel)
   at Progress.Open4GL.DynamicAPI.Session.runStatelessProcedure(String requestID, String fullProcedureName, ParameterSet inparams, Object procId, MetaSchema localSchema, Int32 stateModel)
   at Progress.Open4GL.DynamicAPI.PersistentProc.runTheProcedure(String requestID, String procedureName, ParameterSet parms, MetaSchema schema)
   at Progress.Open4GL.DynamicAPI.PersistentProc.runProcedure(String procedureName, ParameterSet parms, MetaSchema schema)
   at Epicor.Mfg.Core.CallContext.CallContextPersistentProc.runProcedure(String procedureName, ParameterSet parameters, MetaSchema metaSchema)
   at Epicor.Mfg.Core.CallContext.ProxyHelper.CallMethod(String methodName, ParameterSet parameters, MetaSchema metaSchema, BLConnectionPool connPool, Session connection, PersistentProc persistProc, CallContextDataSet callContextDataSet)
First : The supplier must be approved, check the approval checkbox in
supplier entry.
Second: Go into the part, and uncheck the inspection required checkbox.
*Amélie Pelletier*
*Analyste Programmeur / Program analyst*
[image: cid:image001.jpg@01CD5525.2091A820]
*230, Boulevard Nilus-Leclerc*
*L'Islet, Québec (Canada)*
*G0R 2C0*
*Téléphone: 418-247-3986 ext. 2390*
*Fax: 418-247-7925*
*amelie.pelletier@... <brigitte.savoie@...>*
*P* Est-ce nécessaire d’imprimer ce message?
*Please consider the environment before printing this email**.*
*De :* vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]
*Envoyé :* 27 octobre 2014 11:13
*À :* vantage@yahoogroups.com
*Objet :* [Vantage] [E9] Can anyone shed a little light on this error
message?
Thanks in advance!
Error Detail
adding to PO.
Type: Error
Table:
Row:
Field:
Stack Trace
Inner Exception
(7211)
Inner Stack Trace
at
callContextDataSet)
You have an approved supplier for this part (123456-001) but it is not the one tied to the PO Suggestion. From part maintenance go to Actions/Approved Suppliers and either delete the approved supplier you currently have or add this supplier. Once you have at least one approved supplier you cannot use another supplier unless you have added them to the list of approved suppliers. If you have no approved suppliers for the part then you can use any supplier you want
On Monday, October 27, 2014 11:13 AM, "tooheymomster@... [vantage]" <vantage@yahoogroups.com> wrote:
<div id="ygrps-yiv-652958611yiv4596869574ygrp-text">
  <div></div><div style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51, 51, 51);">Can anyone shed a little light on this error message?</div><div style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51, 51, 51);">Thanks in advance!</div><div style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51, 51, 51);">&nbsp;</div><div style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51, 51, 51);"><span style="padding:0px;outline:0px;font-weight:inherit;font-style:inherit;font-family:inherit;vertical-align:baseline;background:transparent;">Exception caught in: Epicor.Mfg.BO.POSugg</span></div><div style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51, 51, 51);">&nbsp;</div><div style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51, 51, 51);">Error Detail</div><div style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51, 51, 51);">============</div><div style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51, 51, 51);">Message: Part (123456-001) is set to Inspection Required, but this is not an Approved Supplier.&nbsp; Make this an Approved Supplier for the part before adding to PO.</div><div style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51, 51, 51);">Type: Error</div><div style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51, 51, 51);">Program: bo/POSugg/POSugg.p</div><div style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51, 51, 51);">Method: GeneratePre56_A1</div><div style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51, 51, 51);">Table:</div><div style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51, 51, 51);">Row:</div><div style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51, 51, 51);">Field:</div><div style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51, 51, 51);">&nbsp;</div><div style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51, 51, 51);">&nbsp;</div><div style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51, 51, 51);">&nbsp;</div><div style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51, 51, 51);">Stack Trace</div><div style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51, 51, 51);">===========</div><div style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51, 51, 51);">&nbsp;&nbsp; at Epicor.Mfg.Proxy.POSuggImpl.Generate(POSuggDataSet ds, String ipPlantKey, String ipCurBuyer, Nullable`1 ipCutOffDate)</div><div style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51, 51, 51);">&nbsp;&nbsp; at Epicor.Mfg.UI.Adapters.POSuggAdapter.Generate(String ipPlantKey, String ipCurBuyer, Nullable`1 ipCutOffDate)</div><div style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51, 51, 51);">&nbsp;</div><div style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51, 51, 51);">Inner Exception</div><div style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51, 51, 51);">===============</div><div style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51, 51, 51);">ERROR condition: The Server application has returned an error. (7243)&nbsp; (7211)</div><div style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51, 51, 51);">&nbsp;</div><div style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51, 51, 51);">Inner Stack Trace</div><div style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51, 51, 51);">=================</div><div style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51, 51, 51);">&nbsp;&nbsp; at Progress.Open4GL.DynamicAPI.Session.runProcedure(String requestID, String procedureName, ParameterSet parms, Boolean persistent, Boolean internal_Renamed, Int64 procId, MetaSchema localSchema, Int32 stateModel)</div><div style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51, 51, 51);">&nbsp;&nbsp; at Progress.Open4GL.DynamicAPI.Session.runStatelessProcedure(String requestID, String fullProcedureName, ParameterSet inparams, Object procId, MetaSchema localSchema, Int32 stateModel)</div><div style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51, 51, 51);">&nbsp;&nbsp; at Progress.Open4GL.DynamicAPI.PersistentProc.runTheProcedure(String requestID, String procedureName, ParameterSet parms, MetaSchema schema)</div><div style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51, 51, 51);">&nbsp;&nbsp; at Progress.Open4GL.DynamicAPI.PersistentProc.runProcedure(String procedureName, ParameterSet parms, MetaSchema schema)</div><div style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51, 51, 51);">&nbsp;&nbsp; at Epicor.Mfg.Core.CallContext.CallContextPersistentProc.runProcedure(String procedureName, ParameterSet parameters, MetaSchema metaSchema)</div><div style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51, 51, 51);">&nbsp;&nbsp; at Epicor.Mfg.Core.CallContext.ProxyHelper.CallMethod(String methodName, ParameterSet parameters, MetaSchema metaSchema, BLConnectionPool connPool, Session connection, PersistentProc persistProc, CallContextDataSet callContextDataSet)</div><div><span></span></div><div style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51, 51, 51);">&nbsp;&nbsp; at Epicor.Mfg.Proxy.POSuggImpl.Generate(POSuggDataSet ds, String ipPlantKey, String ipCurBuyer, Nullable`1 ipCutOffDate)</div><div><span><br class="ygrps-yiv-652958611yiv4596869574yui-cursor"></span></div>
</div>
