E9: Converting VB -> C#: adapter.GetRows parameters
Thanks. I should have tried the obvious. I tried parenthesizes and brackets, but not by itself, duh! Thanks again.
Dan
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of bw2868bond
Sent: Friday, September 21, 2012 6:46 PM
Subject: [Vantage] Re: E9: Converting VB -> C#: adapter.GetRows parameters
dsPartDataSet = partAdapter.GetRows(opts, out MorePages);
--- In vantage@yahoogroups.com, "dgodfrey_amc" <dgodfrey@...> wrote:
> How do you identify the 'out' keyword? Below is my snippet of code and then the error. when I remove the second parameter, I also get an error, saying that there is no overloaded function with one parameter.
> Can someone help?
> string whereClause = "CheckBox02 = True AND TypeCode = 'M'"; bool
> MorePages = false;
> opts.NamedSearch.WhereClauses.Add("Part", whereClause); dsPartDataSet
> = partAdapter.GetRows(opts, MorePages);
> Error: CS1502 - line 445 (2807) - The best overloaded method match
> for
> 'Epicor.Mfg.UI.Adapters.PartAdapter.GetRows(Epicor.Mfg.UI.Searches.Sea
> rchOptions, out bool)' has some invalid arguments
> Error: CS1620 - line 445 (2807) - Argument '2' must be passed with
> the 'out' keyword
Can someone help?
bool MorePages = false;
dsPartDataSet = partAdapter.GetRows(opts, MorePages);
Error: CS1502 - line 445 (2807) - The best overloaded method match for 'Epicor.Mfg.UI.Adapters.PartAdapter.GetRows(Epicor.Mfg.UI.Searches.SearchOptions, out bool)' has some invalid arguments
Error: CS1620 - line 445 (2807) - Argument '2' must be passed with the 'out' keyword
> Can someone help?
