Tom Christie | Information Technology Manager | AGM Container Controls, Inc.<http://www.agmcontainer.com/> | tchristie@...<mailto:tchristie@...> | t: 520.881.2130 ext 2176
Sent: Wednesday, July 16, 2014 10:37 AM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] E9: Customization fails on second load
There are no personalizations. The first error states “Exception has been thrown by the target of an invocationâ€
Stack Trace
at System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner)
at System.RuntimeMethodHandle.InvokeMethodFast(Object target, Object[] arguments, Signature sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at Epicor.Mfg.UI.Customization.CustomScriptMethodInvoker.InvokeScriptMethod(MethodInfo scriptMethod, Object[] parameters)
at Epicor.Mfg.UI.Customization.CustomScriptMethodInvoker.InvokeInitializeGlobalVariables(CustomScriptManager customScriptManager)
at Epicor.Mfg.UI.Customization.CustomScriptManager.<InitializeCustomAssembly>b__13()
at Epicor.Mfg.UI.Customization.CustomScriptManager.TryActionShowExceptionBoxIfException(Action action, String exceptionBoxTitle)
Inner Exception
Object reference not set to an instance of an object.
Inner Stack Trace
at Script.InitializeGlobalVariables(CustomScriptManager csm)
After that error, a few more come up for a few elements I added via the toolbox.
Sent: Tuesday, July 15, 2014 12:04 PM
To: Vantage
Subject: Re: [Vantage] E9: Customization fails on second load
What do you mean by corrupted version?
Try deleting the personalizations
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
E: jose@...<mailto:jose@...>
http://www.josecgomez.com
[Image removed by sender.]<http://www.linkedin.com/in/josecgomez> [Image removed by sender.] <http://www.facebook.com/josegomez> [Image removed by sender.] <http://www.google.com/profiles/jose.gomez> [Image removed by sender.] <http://www.twitter.com/joc85> [Image removed by sender.] <http://www.josecgomez.com/professional-resume/> [Image removed by sender.] <http://www.josecgomez.com/feed/>
On Tue, Jul 15, 2014 at 2:59 PM, 'Tom J. Christie' tchristie@...<mailto:tchristie@...> [vantage] <vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>> wrote:
Okay, this is bonkers.
I have a customized version of the Quote Entry screen.
IF you clear cache and open it, it downloads from the server and opens correctly.
If you then close it and reopen the form, it errors out and opens a corrupted version. It will do this every time until you clear the cache again.
So, it appears to work when you download it fresh, but fails if you have already downloaded it. Help!
Regards,
Tom Christie | Information Technology Manager | AGM Container Controls, Inc.<http://www.agmcontainer.com/> | tchristie@...<mailto:tchristie@...> | t: 520.881.2130 ext 2176<tel:520.881.2130%20ext%202176>
