E9 Customization VB.Net
Austin asks:
> Okay, now you have me interested. Why c#?
Without getting into a religious war on programming languages, the
main reason to do customizations in C# depends on if you'll ever use
EpicorAnywhere, i.e. the web version of Epicor. The process that
generates web pages from the Windows Forms files knows how to convert
C# to JavaScript but not VB.
Mark W.
I am starting to work on Customizations in E9 and the programming language is set to C#. I want to just transfer my VB.Net code over. Is there a way to change the programming language.
Scott
Yes but you don't want to :-)
Joking aside its on the Script Tab, you can choose between VB and C#
although I STRONGLY ADVICE YOU STICK WITH C# there is even a tool that will
help you convert your code. within Epicor.
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.usdoingstuff.com>
> Thanks,
> Scott
Austin Skrepak
Data Specialist / Developer
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jose Gomez
Sent: Thursday, November 15, 2012 1:32 PM
To: Vantage
Subject: Re: [Vantage] E9 Customization VB.Net
Joking aside its on the Script Tab, you can choose between VB and C# although I STRONGLY ADVICE YOU STICK WITH C# there is even a tool that will help you convert your code. within Epicor.
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Thanks,
> Scott
You know I always wondered the same thing. They functionally work the same... I used to code in VB.NET only and Jose talked me into moving to C#. I don't know why, but I love it, I will never go back. I've even gone back and converted old scripts to C# from .NET. Maybe it's just a personal preference thing but C# ROCKS!
> Austin Skrepak
> To: Vantage
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Thanks,
> > Scott
*Mostly joking*
Because that's what real programmers do! heh
Ok ok... I'll take bashing for that, but never the less. Epicor (Client)
is written in C# not VB, and although the .NET framework will take either,
if in the future Epicor were to move up in a different direction VB may not
be supported. C# is more restrictive which is good in an environment where
making logic errors can be a bad thing. VB will take a lot
of liberties that C# won't with typing and casting which are generally
friendlier to the developer its a lot easier to assign an int to a string
and not have to worry about casting but in the end this could lead to
strange behavior which could bite you in the butt.
However I acknowledge that in the end you are using the same managed code /
framework and the byte code will likely be identical.
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Austin Skrepak
> Of Jose Gomez
> To: Vantage
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Thanks,
> > Scott
Jose,
I am versed in VB and not C# (starting my schooling in January for
programming - yeah) but I am under a time crunch so I want to stick with VB
for now and then I will convert down the road when I have more time. Though
if the tool works I am not opposed to using it.
On my Script Tab the C# and VB.Net radio buttons are greyed out.
Scott
Jose Gomez
To: Vantage
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Thanks,
> Scott
You don't have to do 'AndAlso' in c#.
That should be reason enough for anyone.
*John Driggers*
*Chief Data Wrangler*
*I have an Epicor blog <http://usdoingstuff.com/>. How useful is that?*
*:: 904.404.9233
:: waffqle@...
:: http://www.usdoingstuff.com <http://www.usdoingstuff.com/>
On Thu, Nov 15, 2012 at 2:51 PM, Jose Gomez <jose@...> wrote:
> *Mostly joking*
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Austin Skrepak
> > Of Jose Gomez
> > To: Vantage
> will
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > > Thanks,
> > > Scott
> have
Never Mind, found it. It is set on the way into the customization on the
Select Customization screen.
Where is that Tool you mentioned?
Scott
Scott Litzau
Sent: Thursday, November 15, 2012 2:00 PM
Subject: RE: [Vantage] E9 Customization VB.Net
Jose,
Scott
Behalf Of
Jose Gomez
To: Vantage
*Jose C Gomez*
*Software Engineer*
E: jose@... <mailto:jose%40josecgomez.com>
> Thanks,
> Scott
That's probably because you already have some C# code or some changes.
Click the new Layer button. HOWEVER BE WARNED. EXISTING CODE WILL NO LONGER
WORK you'll have to re-write it/.
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Thu, Nov 15, 2012 at 3:00 PM, Scott Litzau
> Jose,
> Scott
> Of
> Jose Gomez
> To: Vantage
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Thanks,
> > Scott
ROTFL I like that you get short circuit for free
*Jose C Gomez*
*Software Engineer*
E: jose@...
> *John Driggers*
> *:: 904.404.9233
> :: waffqle@...
> > *Mostly joking*
> either,
> not
> where
> code /
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > > Austin Skrepak
> Behalf
> > > Of Jose Gomez
> > > To: Vantage
> > will
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@...
> Is
> > > > Thanks,
> > > > Scott
> > have
> and
I don't hve a 9X install in front of me but its in Sys Mtm ->Utils
Customization Maintennace.
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Thu, Nov 15, 2012 at 3:03 PM, Scott Litzau
> Scott
> Of
> Scott Litzau
> Jose,
> Scott
> Behalf Of
> Jose Gomez
> To: Vantage
> *Jose C Gomez*
> *Software Engineer*
> > Thanks,
> > Scott
