I have a dashboard with two date parameters StartDate and EndDate. the EndDate shows up above the startdate which is counterintuitive. Can’t seem to get them arranged - appears to be alphabetical???
I’m assuming a tracker view? Did you customize them at all? If not, you should be able to right click on the Tracker View and go to Properties and then there should be an up and down arrow off to the right. You click on the End Date and click the down arrow and it will move it below the Start Date. Of course, that’s how it is in E10, I’m not sure if E9 user interface looks the same.
