E9 - DMT to update part revisions
Very strange outcome. Even though DMT was throwing errors on all of the rows in the DMT spreadsheet, it did actually remove the operations for all of the rows. We found we had to run the DMT twice. The first time checked the part revision into the Engineering Workbench. The second pass performed the deletes of the operations. The error thrown for the second pass was.
2013-01-12T07:06:07 01-56-001-00 20 Method (ecoopdtlAfterGetNew) Table ECOOpr Record not available.
For the recored, we are running 700C.
Tim
--- In vantage@yahoogroups.com, "Lisser, Jennifer" wrote:
> I use the DMT to update MOMs all the time. The DMT follows the same logic as Epicor, so if you can delete the operations manually you can delete them using the DMT. Make sure you have the required fields to delete the BOM (there is a button you can click to list them). If it's operations you want to delete the associated material has to be deleted first. If you still can't run your update after those checks post the error message.
Has anyone had any luck with modifying part methods via DMT? We want to simply delete a few operations on a couple hundred parts. fortunately, not the operation that has material, so we thought it would be possible, but we are getting errors when trying.
Before going live and when we found a large data error, we would delete the part revision all together and start over. With a couple weeks of production, not an option we can exercise anymore.
Tim
What errors are you getting?
Marco Vissuet
Systems Engineer
Pacific Contours Corporation
Office (619) 670-3900
Fax (619) 670-1643
mvissuet@...<mailto:marcov@...>
http://www.pacificcontours.com/
"The information contained herein may be subject to the International Traffic in Arms Regulations (ITAR) Warning: - This document contains data whose export is restricted by the Arms Export Control Act (Title 22, U.S.C., Sec 2751, et seq.) as amended, or the Export Administration Act (Title 50, U.S.C., App 2401 et seq.) as amended. Violations of these export laws are subject to severe criminal and civil penalties. Disseminate in accordance with provisions of DoD Directive 5230.25.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Tim Vonderhaar
Sent: Friday, January 11, 2013 1:48 PM
Subject: [Vantage] E9 - DMT to update part revisions
Tim
