E9: Edit quote after if is won
Thanks Linda.
It's weird because we can uncheck the box when the quote is closed,
although we cannot save it but once we open the quote it is greyed out
on both the summary and the header.
Of Linda Lowney
Sent: Wednesday, July 06, 2011 5:13 PM
Subject: RE: [Vantage] Re: E9: Edit quote after if is won
Hi Joe,
I don't know if it is related to your problem, since we are still on
8.03.407, but sometimes we can't unclick the Quoted checkbox that is
located on the Summary screen, but if we go to the Header screen we can.
One of Vantage's little quirks.
Regards,
Linda
Behalf
Of Joe Rojas
Sent: Wednesday, July 06, 2011 4:47 PM
Hi Virginia,
I got more details from my users after I posted this email.
We can reopen a won quote but we cannot uncheck the "Quoted" checkbox.
Not being able to do this, prevents us from unchecking the "Engineered"
checkbox on the lines, which stops us from going into the configurator
for a configured line.
It seems that most every other field can be updated except the
"Engineered" checkbox. We can change the template checkbox, which I
thought was the problem.
Because we do not have an actual engineering department or a need to
check the line as engineered, we are going to remove this checkbox from
the screen, which should "fix" our problem.
Behalf
Of Virginia Joseph
Sent: Wednesday, July 06, 2011 3:30 PM
Subject: [Vantage] Re: E9: Edit quote after if is won
We are on version 8.03.408 and we do not need to mark our quote lines as
templates in order to pull the mfg. details into the job. We create the
sales order lines using New Line from Quote in Order Entry.
Most our quotes are for configured items with mfg. details and none of
our quotes are marked as templates and the details pull into the job
fine. Maybe a bug in E9?
As far as openeing a won quote, we have never has a problem by simply
going to Quote entry, Actions, Quote, Reopen Quote. (The quote is still
indicated as won.) We make necessary changes then select Actions, Quote,
Close quote. No problems. E9 will not allow you to simply reopen the
quote? Maybe another reason we are in no hurry to upgrade...
Virginia Joseph
Deep Hole Specialists, LLC
vjoseph@... <mailto:vjoseph%40deephole.com>
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
<mailto:vantage%40yahoogroups.com> , Joe
Rojas <jrojas@...> wrote:
> Hello,
> Most of our quotes are for configured items that result in a method of
> manufacturing.
> After the a sales order is created from the quote, we then create a
job
> and pull the details from the quote.
> You can only pull the details from the quote line if it is marked as a
> Template.
> Due to human error, we are finding that not all lines are marked as
> templates when applicable.
> At the same time, we cannot find a way to reopen the quote after it
has
> gone into a WON status.
> Does anyone know to reopen a won quote?
> Thanks.
> Joe Rojas | Director of Information Technology | Mats Inc
> dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
> jrojas@... | www.matsinc.com Ask us about our clean, green and
beautiful matting and flooring
> This message is intended only for the individual named. If you are not
the named addressee you should not disseminate, distribute or copy this
e-mail. Please notify the sender immediately by e-mail if you have
received this e-mail by mistake. Please note that any views or opinions
presented in this email are solely those of the author and do not
necessarily represent those of the company.
jrojas@... <mailto:jrojas%40matsinc.com>
<mailto:jrojas%40matsinc.com> | www.matsinc.com Ask
us about our clean, green and beautiful matting and flooring
jrojas@... | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
Hello,
manufacturing.
After the a sales order is created from the quote, we then create a job
Template.
At the same time, we cannot find a way to reopen the quote after it has
Thanks.
Good Day Joe:
As a work around, can you copy the quote, mark it Template, and then
use it?
I thought any quote could be copied? The Template designation was
just a way to limit the number of returns if a search is done for
quotes; but I am not sure, and I am on E9.05.601B.
len.hartka@...
Of Joe Rojas
Sent: Wednesday, July 06, 2011 11:26 AM
Subject: [Vantage] E9: Edit quote after if is won
Hello,
manufacturing.
Template.
Thanks.
jrojas@... <mailto:jrojas%40matsinc.com> | www.matsinc.com Ask
This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
We are on version 8.03.408 and we do not need to mark our quote lines as templates in order to pull the mfg. details into the job. We create the sales order lines using New Line from Quote in Order Entry.
Most our quotes are for configured items with mfg. details and none of our quotes are marked as templates and the details pull into the job fine. Maybe a bug in E9?
As far as openeing a won quote, we have never has a problem by simply going to Quote entry, Actions, Quote, Reopen Quote. (The quote is still indicated as won.) We make necessary changes then select Actions, Quote, Close quote. No problems. E9 will not allow you to simply reopen the quote? Maybe another reason we are in no hurry to upgrade...
Virginia Joseph
vjoseph@...
--- In vantage@yahoogroups.com, Joe Rojas <jrojas@...> wrote:
> Hello,
> manufacturing.
> Template.
> Thanks.
Hi Virginia,
Of Virginia Joseph
Virginia Joseph
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , Joe
> Hello,
> manufacturing.
job
> Template.
has
> Thanks.
Hi Joe,
Regards,
Linda
Of Joe Rojas
Hi Virginia,
Behalf
Of Virginia Joseph
Virginia Joseph
> Hello,
> manufacturing.
job
> Template.
has
> Thanks.
