We take those numbers and insert to EPICOR as Forecast. That is how we build the products.
We created a shared warehouse. Plant 1 will build to FG WH then xfer the parts to TCONS WH (Shared). Plant 2 will build to T-FG and xfer to TCONS WH as well. TCONS WH is used to represent what we “SENT†to the customer. Note I said SENT and not SHIPPED.
So that production can know when to SEND a product out, I created a uDash based off a UD table that represents pseudo shipments. This UD Table is maintained by the planners based on the forecast the customer gives us from the portal. It gives them the PN, QTY and Date. The shippers are able to update certain fields for Tracking and mark off via check box to indicate shipped. This checkbox hides the line from being seen.
The shipper then prints out a fake packing slip that we created based off Part Number, no PS will be printed of the Order is closed. The PS # is the PLANTID-DATE-mmss. Then these are sent to the customer and the product is transferred to the shared WH.
Once the customer uses the product, our Customer Service Manager uses Customer Shipment Entry to process the usage. This then will create the invoice for payment.
Miguel A. Santillan
Compass Manufacturing Systems
Sent: Monday, September 14, 2015 6:57 AM
Subject: RE: [Vantage] Re: E9: How do you handle consignment material?
Hi Miguel,
Did you ever put together a good process in the system for consignment? I have a plant in Mexico that is on Vantage 6.1, they currently use a dummy company to handle this, but I'd like to make it all visible when they upgrate to 9.05 later this year. Hoping you found something that works! All the posts I've read through seem to have a convoluted process.
John Sieacki
Dudek & Bock Spring Mfg Co
