E9 - Importing from Solid Edge
Does anyone import a BOM into E9 from solid edge? Do you have a template that you use that you are willing to share? Any problems or issues. I am going to start looking at this today.
Best Regards,
Dina M. Hieber
Vamco International, Inc.
555 Epsilon Drive
Pittsburgh, PA 15238
(412) 963-7100 x 203
(412) 963-9511
www.vamcointernational.com<http://www.vamcointernational.com>
This e-mail message and any files transmitted with it are confidential and are intended for the sole use of the intended receipient(s). Any unauthorized use or disclosure is prohibited. Any opinions express in the email are those of the individual and not necessarily the company. If you are not the intended recipient, please contact the send by reply email and destroy all copies of the original message.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of jgiese1988
Sent: Tuesday, November 20, 2012 8:51 AM
Subject: [Vantage] Re: Handheld customisation problem
Open your customization > Click the form element at the top of the tree in the left hand side of the customization window > Set location to 0,0 and save.
If that does not work go into the XML and modify that manually, then ensure that there are no anchor properties set on the form window.
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "nbuckman@...<mailto:nbuckman@...>" <nbuckman@...<mailto:nbuckman@...>> wrote:
> Hello,
> I have customised the PackOut screen. the customisation works fine on a PC, but on a handheld device the screen cannot be seen because it has moved to the right and down a bit.
> If I try it in the handheld demo menu, the screen jumps out of the scanner window and floats above it.
> How can I get the customised screen to stay in the same palce as the uncustomised version? When it is opened in the customisation you can't move the form on the screen, but it is in the wrong place.
> - Neil
