E9 - move Sales Order Entry customization from Production to Tes
Thank You!!!
Charlie Smith, Miguel Santillan and Cathy!!!!
It worked like a charm and was easier than I thought. These kinds of things become tricky when you are new and when there is not a lot of documentation, written, online or otherwise....
I have the Epicor books and must have read through them at least a few dozen times and not once, did I find that in there.
Again, thank you so much!!!
I am trying to move a customization of Sales Order Entry from Production to Test. I have searched online and looked through my books and have not found the answer.
I originally thought to do a search through BAQ's but was unsuccessful. I knew that this was not a BAQ but had to try...
Create a solution and then import the solution into the test system.
Sent: Wednesday, October 01, 2014 5:01 PM
Subject: [Vantage] E9 - move Sales Order Entry customization from Production to Test
Go into developer mode.  Open Order Entry and your customization.
Right click and CUSTOMIZE
FILE > EXPORT CUSTOMIZATION
Then in your test.
ULTILITIES > CUSTOMIZATION
IMPORT.
Miguel A. Santillan
Compass Manufacturing Systems
Sent: Wednesday, October 1, 2014 3:01 PM
Under Systems Management > Utilities > Customization Maintenance - Under Actions – Export the customization.
While you are in the Customization – under File – you can also export.
Then import into Production.
Sent: Wednesday, October 01, 2014 3:01 PM
