E9 PO Suggestions
Thanks John and Ted.
We will use the additional process, just hoping for a more direct solution.
Greg
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of John Driggers
Sent: Wednesday, December 14, 2011 10:10 PM
Subject: Re: [Vantage] E9 PO Suggestions
We've tried to do this on a couple occasions with limited success. As best I recall, none of the methods will give you a hook to the actual suggestions. Your best bet will likely be to fire an additional process afterwards that scans the Suggestions and makes your changes. I know it's a bit clunky, but it works well.
On Wed, Dec 14, 2011 at 6:54 PM, Ted Koch <tkoch77@...> wrote:
> Have you tried creating a method directive using PoSugg and the
> Generate method?
> Ted
> From: Greg Payne <gpayne@...>
> To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
> Sent: Wednesday, December 14, 2011 2:47 PM
> Subject: [Vantage] E9 PO Suggestions
> We want to run a process to edit PO suggestions just after generate po
> suggestions finishes running. PO suggestion is a process not a method,
> so I can't do post processing.
> I tried this data directive on the SysTask table, but it doesn't trigger.
> for last SysTask no-lock where SysTask.Company = 'COMP01' and
> SysTask.TaskType = 'Process' And SysTask.TaskDescription BEGINS
> 'Generate PO Sugg' And SysTask.TaskStatus = 'COMPLETE'
> Thanks for any suggestions.
> Greg Payne
> Compulink
> CONFIDENTIALITY NOTICE
> The information contained in this communication, including
> attachments, is privileged and confidential. It is intended only for
> the exclusive use of the addressee. If the reader of this message is
> not the intended recipient, or the employee or agent responsible for
> delivering it to the intended recipient, you are hereby notified that
> any dissemination, distribution or copying of this communication is
> strictly prohibited. If you have received this communication in error,
> please notify us at (727) 578-6258 and immediately delete the communication.
> "This (document/presentation) may contain technical data as defined in
> the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10.
> Export of this material is restricted by the Arms Export Control Act
> (22 U.S.C. 2751 et seq.) and may not be exported to foreign persons
> without prior approval form the U.S. Department of State."
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access.
> (1) To access the Files Section of our Yahoo!Group for Report Builder
> and Crystal Reports and other 'goodies', please goto:
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
*John Driggers*
*High End Dev, System Design, Profit Drinking
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at (727) 578-6258 and immediately delete the communication.
We want to run a process to edit PO suggestions just after generate po suggestions finishes running. PO suggestion is a process not a method, so I can’t do post processing.
I tried this data directive on the SysTask table, but it doesn’t trigger.
for last SysTask no-lock where SysTask.Company = 'COMP01' and SysTask.TaskType = 'Process' And SysTask.TaskDescription BEGINS 'Generate PO Sugg' And SysTask.TaskStatus = 'COMPLETE'
Greg Payne
Compulink
Have you tried creating a method directive using PoSugg and the Generate method?
Ted
Greg Payne
Compulink
Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have already linked your email address to a yahoo id to enable access. )
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.%c2%a0
> method?
> Ted
> can�t do post processing.
> I tried this data directive on the SysTask table, but it doesn�t trigger.
> Greg Payne
> Compulink
*John Driggers*
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
