E9: Product Configurator Error - "Size" limit?
I had once such a problem with a configurator.
It wasn't such a big configurator but one that I played too much with it.
The solution I had in the end was by deleting the file that got the error and by approving it got recreated.
Ephraim Feldman
Date: Tue, 15 Jun 2010 15:08:00
To: <vantage@yahoogroups.com>
Subject: [Vantage] E9: Product Configurator Error - "Size" limit?
Hi All,
Is there a "size" limit on a configurator, either in regards to number
of inputs or lines of code?
We have a configurator, probably our biggest one that went flaky a day
ago and I can't figure out why. I'm going through it with a fine tooth
comb but no luck so far.
By flaky, I mean that we cannot Approve it. When we try we get:
Compilation error in a Prompt When expression.
File 'D:\EPICOR904\Server\pcrules\MATS\JR Mat Config gvREV B2-PW.p' at
line 7399 column 83. Error 232.
When I read the specified line, there is nothing wrong with it. I've
cleared out ALL Prompt When code and I still get the same error (just
different line number).
Joe Rojas | Director of Information Technology | Mats Inc
dir: 781-573-0291 | cell: 781-408-1264 | fax: 781-341-5694
jrojas@... | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
Hi All,
Remove that line of code and see if it will allow you to approve the
configuration.
Blake Clemens
IT Systems Engineer
Delmarva Millwork Corporation
(800) 360-2364 x132
Of Joe Rojas
Sent: Tuesday, June 15, 2010 3:08 PM
Hi All,
jrojas@... <mailto:jrojas%40matsinc.com> | www.matsinc.com Ask
