Ah, the key is your last point "Use Serial Mast Starting Sequence". Without that, each part will generate independently. Checking this will make the sequence number available globally which is exactly what we want.
Thanks very much!
Tim
Thanks very much!
Tim
--- In vantage@yahoogroups.com, Mark Wonsil <mark_wonsil@...> wrote:
> Doug wrote:
> > You have to create a Serial "Mask" with type "Generation" and assign each serialized part number to use that "Mask" as its source.
> > Each global serial number mask generates its own sequence of serial numbers and all part assigned to the same mask share that set.
> Doug is right. Start with Material Management | Inventory Management |
> Setup | Serial Mask Maintenance
> This is where we create our single SN mask as a Generation Type, a
> mask like yours "<yy><m>#####, and a starting sequence.
> Then, for each serialized part, we set the mask to this entry by
> clicking on the SN Format button, choose Serial Mask for the Base
> Number Structure, select from the Serial Mask and then clicking the
> We're still 9.04 but I think it's still the same.
> Mark W.
