E9 - Setup Labor Type, Labor Qty Question
Thanks guys.
--- In vantage@yahoogroups.com, "Tom J. Christie" <tchristie@...> wrote:
> We use the setup time to capture the setup and first article production time. In our case the setup qty becomes 1 and the production quantity is the remainder. You can use it however you want but Epicor does sum the setup and production qty together for the operation.
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Greg Payne
> Sent: Sunday, November 25, 2012 11:02 PM
> To: vantage@yahoogroups.com
> Subject: RE: [Vantage] E9 - Setup Labor Type, Labor Qty Question
> We are newly implemented and we have found that quantities are production only. I also got the bpm to stop over reporting of labor quantities from the file section here to stop the extra labor quantities.
> Greg
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Tim Vonderhaar
> Sent: Saturday, November 24, 2012 2:06 PM
> Subject: [Vantage] E9 - Setup Labor Type, Labor Qty Question
> While testing, we have noticed that when we enter Labor Qty on a Time and Expense Entry for a setup labor type (we are making 2 parts, so we entered 2 for the setup), the Production Detail Report appears to add the setup quantity together with the production labor type Labor Qty. With our actual production Labor Qty also at 2, the Production Detail Report quantity shows a total of 4 completed, double what we expected. That said, is this expected behavior or should we leave the Labor Qty on a setup labor type entry at zero?
> Thanks,
> Tim
> CONFIDENTIALITY NOTICE
> The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
> "This (document/presentation) may contain technical data as defined in the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10. Export of this material is restricted by the Arms Export Control Act (22 U.S.C. 2751 et seq.) and may not be exported to foreign persons without prior approval form the U.S. Department of State."
Tim
Greg
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Tim Vonderhaar
Tim
Greg
Tim
