E9 speed gain from patching up
When I ran the web installer from: http://www.microsoft.com/downloads/details.aspx?FamilyID=2da43d38-db71-4c1b-bc6a-9b6652cd92a3&displaylang=en
It DID install several updates, but I noted that the version number did not change at all from what it was previously when I check by running dxdiag. But if I attempt to run the installer again, it says I'm up to date.
Before update: 9.0c 409.0000.0904
After update: 9.0c 409.0000.0904
Plus, I've not really noticed much an improvement in performance though.
Maybe the original poster had clients that were way out of date, like even an old XP SP?
--- In vantage@yahoogroups.com, Chris Thompson <chriselectrix@...> wrote:
> I would also be interested to know.
> Just done a quick Google search and that suggests...
> Windows XP - DirectX9
> Windows Vista - DirectX10
> Windows 7 - DirectX11
> It suggests these are the maximum you can go upto but I would like to know if
> this is true.
> Thanks,
> CHRIS
> From: that_guyy <rbird@...>
> To: vantage@yahoogroups.com
> Sent: Wed, 1 September, 2010 14:08:44
> Subject: [Vantage] Re: E9 speed gain from patching up
> ÂÂ
> I just need some clarification:
> 1. What DirectX version is being referred to here? DirectX 11?
> 2. What platform is it being installed on? Windows XP SP3?
> 3. What is the URL for the installer?
> 4. Does anyone have any recommendations on how to mass deploy?
> Thanks,
> Rick
> --- In vantage@yahoogroups.com, Tony Hughes <thughes281@> wrote:
> > That is bizarre, but I will try it.
> > From: leann_37 <lmarruffo@>
> > Sent: Tue, August 31, 2010 12:58:00 PM
> > Mark,
> > THANK YOU SO MUCH. We installed the latest DirectX on both Citrix and client
> > machines, and save and refresh times dropped like a stone. The initial form
> > cache is still obnoxious, as are the search times, but the refresh times and
> > save times are so much better.
> > Can't thank you enough for taking the time to mention this. It wouldn't have
> > occured to me in a hundred years.
> > - leAnn
> > --- In vantage@yahoogroups.com, "Kerry_Muntz" <kerry_muntz@> wrote:
> > > Gidday Mark - I've done a lot of digging to see what would improve our user
> > >experience here (especially for our battered quoting team), but haven't come
> > >across this DirectX issue before.
> > > In what areas did you see the improvements? What scale of improvement? Is MES
> > >also improved?
> > > We're on 8.03.405A and I'm happy to do some "before and after" testing - if I
> > >know where to best measure... If this is worth doing, I'll need some degree of
> > >evidence to show our IT guy to warrant his rolling out the DirectX changes.
> > > cheers kindly
> > > Kerry.
> > > --- In vantage@yahoogroups.com, Mark Wonsil <mark_wonsil@> wrote:
> > > > Hi leAnn,
> > > > > Our end users all access through Citrix, but all clients are Windows XP.
> > > > In the early days of Vantage 8.03, I remember that we got a speed
> > > > increase when we updated to the most current version of DirectX. The
> > > > download is everywhere but I would get it from Microsoft's site.
> > > > Mark W.
All,
Is there a gain to be had in performance simply by updating from 9.04.506 to 9.04.506c? Reading the patch guide, I don't see anything that would lend itself to this, but my admin "heard" it, so I am asking the experts. Our biggest issues are on loading and caching forms the first time used, search routines, save, and refresh. All are very slow.
Any assistance would be greatly appreciated!
Thanks!
- leAnn
What OS is on your desktops?
--- In vantage@yahoogroups.com, "leann_37" <lmarruffo@...> wrote:
> All,
> Thanks!
> - leAnn
Thanks!
- leAnn
> --- In vantage@yahoogroups.com, "leann_37" <lmarruffo@> wrote:
> > All,
> > Thanks!
> > - leAnn
Hi leAnn,
Mark W.
Gidday Mark - I've done a lot of digging to see what would improve our user experience here (especially for our battered quoting team), but haven't come across this DirectX issue before.
In what areas did you see the improvements? What scale of improvement? Is MES also improved?
We're on 8.03.405A and I'm happy to do some "before and after" testing - if I know where to best measure... If this is worth doing, I'll need some degree of evidence to show our IT guy to warrant his rolling out the DirectX changes.
cheers kindly
Kerry.
--- In vantage@yahoogroups.com, Mark Wonsil <mark_wonsil@...> wrote:
> Hi leAnn,
> Mark W.
Hi Kerry,
This improvement was found completed by accident. The person who did
workstation updates just tried it and the screen painting went a lot faster
(twice maybe?). Now all workstations were Dell and it may have had something
to do with the particular graphics card. I don't know for sure since we
didn't expect the improvement but each system we updated did seem to work
better. That was a few years ago now and on XP, so your mileage may vary.
(Would you say your meterage may vary???)
Cheers,
Mark
> MES also improved?
> changes.
> cheers kindly
> Kerry.
> --- In vantage@yahoogroups.com <vantage%40yahoogroups.com>, Mark Wonsil
> > Hi leAnn,
> XP.
> > Mark W.
Thanks Mark. Yeah, you'd think it'd be meterage - but it's not ;-) The imperial legacy is pretty hard to shake - even for those of us born after the decimal takeover.
We're still on XP here - but all the power users seem to be on the latest official DirectX possible. It was worth a look though.
regards
Kerry
> Hi Kerry,
> Cheers,
> Mark
> > MES also improved?
> > changes.
> > cheers kindly
> > Kerry.
> > > Hi leAnn,
> > XP.
> > > Mark W.
Mark,
THANK YOU SO MUCH. We installed the latest DirectX on both Citrix and client machines, and save and refresh times dropped like a stone. The initial form cache is still obnoxious, as are the search times, but the refresh times and save times are so much better.
Can't thank you enough for taking the time to mention this. It wouldn't have occured to me in a hundred years.
- leAnn
> cheers kindly
> Kerry.
> > Hi leAnn,
> > Mark W.
Mark,
- leAnn
>also improved?
> cheers kindly
> Kerry.
> > Hi leAnn,
> > Mark W.
Rick
> From: leann_37 <lmarruffo@...>
> Mark,
> - leAnn
> >also improved?
> > cheers kindly
> > Kerry.
> > > Hi leAnn,
> > > Mark W.
this is true.
CHRIS
Â
Rick
> Mark,
> - leAnn
> >also improved?
> > cheers kindly
> > Kerry.
> > > Hi leAnn,
> > > Mark W.
