E9 - Updateable Dashboard to change GL Allocation Detail
I am looking to build an updateable dashboard to modify the allocations stored in GLAlcDtl. The GL Allocation form will allow a grid update, but it is specific to a particular GL account. I am looking to make an updateable dashboard to allow mass change.
I added the GLAlcHed and GLAlcDtl table and the Hed.company, Hed.AllocID, Dtl.AllocLine, and Dtl.AllocationUnits fields.
I marked the allocationunits as updateable and turned on multiple rows.
I disabled advanced BPM update only and selected the GLAlcHed Bo and UpdateExt method.
I marked ttGLAlcHed and TtGLAlcDtl tables to be updated and made sure the column mapping populated an expression for each field.
I regenerated the directive.
I went to test it. Get List worked. Modify two values on the allocation units (swapped them).
Clicked 'update' and boom... "No header records found - processing aborting."
Any ideas?
Tom Christie
Information Technology Manager
AGM Container Controls
3526 E Ft. Lowell Road
Tucson, AZ 85716
PH: 520-881-2130
EM: Tchristie@...
